Need help troubleshooting LG 50PC3D
  • jettboat
    • Nov 2012
    • 63
    Re: Need help troubleshooting LG 50PC3D
    well I finally got the 3d one working the ipms 15 & 16c were open not shorted on both buffers were good
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      After all of...
      07-13-2024, 08:14 PM
    • Nicktronic
      Samsung Power Supply Board BN44-00874F
      by Nicktronic
      Hey everyone,
      This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
      Anybody...
      03-17-2025, 06:20 AM
    • Per Eriksson
      Samsung BN44-00808D power supply board troubleshooting
      by Per Eriksson
      I was given a samsung 65" lcd tv which is "dead" after a lightning strike.
      Power supply board is a BN44-00808D , also have the marking L65S6N_FSM
      Main board is a BN94-10803V
      I've made some simple test.
      With main board connected nothing happens when plugged in, no blinking lights or sounds.
      Also kept it plugged in for a while and checked on the boards with a thermal camera, no hot spots detected.
      With the main board disconnected the backlights turn on and stay on.
      Checked the voltages...
      06-01-2021, 02:51 AM
    • shamsudeen
      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
      by shamsudeen
      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
      i know that in linear power supply the noise will be very low comparing to SMPS supply....
      07-19-2025, 07:14 AM
