Insignia NS-L26Q-10A no pic or sound or light
  • Joatmon
    • Aug 2012
    I trying to help a friend out he has a Insignia NS-L26Q-10A that will not power up no light at all no where. I open it up and check the capacitors and I do not find any that looks bad. I check the voltage from the power supply and only have 5 volt no other volt reading.
    Power supply number is 715G2907-1-3 my question is, is it the power supply or the main board?
    Sorry I don't have any pictures.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Insignia NS-L26Q-10A no pic or sound or light
    Are you likely to have any pictures -without them its very difficult.
    "Power supply number is 715G2907-1-3 my question is, is it the power supply or the main board?"
    Its a bit like saying My car wont go- its a blue ford with v6 engine - the lights come on - my question is is it the battery, the plugs, carb , petrolpump, engine,clutch, gearbox.
    Try checking any fuses and fusible resistors front and back of boards.
    Loose connectors, loose components, cold joints resolder transformer joints
    big resistors and big diodes.
    • Joatmon
      • Aug 2012
      Thanks I will look at it more and check more out. I was trying to get pointed in the right direction like the power supply or main board and you said it cold be ether one so I guess I will start with the power supply.
      Thanks Again
      • retiredcaps
        • Apr 2010
        • 9271
        If you have no power LED at all but have 5V standby on the power supply, start with the main board and check the voltage regulators. I have written about how to measure the above several times especially for Vizio TVs.
        --- begin sig file ---
        --- end sig file ---
          Does it look like this?
          http://www.shopjimmy.com/insignia-ad...upply-unit.htm
          We are trying to troubleshoot the problems without having the TV or the boards in front of us, so good pictures are a must.
          There are more than one version and manufacturers for this model.
          • Joatmon
            • Aug 2012
            Yes it does and thanks for the help. I'm working some long hours and will be off for a while after Thursday and I will post some pictures after I do a few more test.
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
              Lithonia Lighting versus Light of America Compact Fluorescent product quality
              I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
              I also have back when Light of America had these light bulbs available for yard lights
              The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
              While the Lithonia lighting fixture has all most certain bulb failure
              So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
              I have only had this light fixture for not more than a year if it...
              07-02-2023, 03:45 PM
            • xl600
              Lexmark 544dn power supply buzzing sound model 40x5409
              by xl600
              I have a Lexmark 544DN laser printer which I'd prefer not to throw away. I know I can buy a new power supply for about $150, but the printer isn't even worth that at this point.
              The printer started acting up about a year ago. Sometimes it would power on normally, sometimes not. When if failed, it would make a single 'click', flash the LED and display backlight, then go completely dark. I got used to this but now it refuses to power on no matter how nicely I talk to it.
              Having a workbench, o-scope, and all sorts of fancy tools, I figured I might try to find the issue myself....
              07-20-2020, 09:21 AM
            • niimi93
              Laptop No Longer Recognizes TV Sound Bar
              by niimi93
              I'll begin with the fact I don't know what change I made to my laptop that triggered this cause. I use my laptop as a pseudo PC by just connecting it to my big smart TV and using a wireless keyboard and mouse. I have a sound bar connected to the TV via optical audio toslink cable. I have game consoles connected to the TV. The game consoles and Netflix/other media apps installed on the smart tv all work properly playing sound through my sound bar with no issues. My laptop, until recently, was playing sound through the TV sound bar just fine as well. I don't know what change I made, and I don't...
              04-25-2023, 07:43 PM
            • 7dalibor7
              Lumenia street light; LED power supply driver
              by 7dalibor7
              Hello, I've got driver module of a LED street light lamp that had an ant colony inside and probably due to some ant organic fluid driver module shorted.
              Fuse is blown, one of the znr varistor is shorted and there is a burnt resistor from which I cant read the value.
              Does anyone by any chance has a schematics for this driver?
              Thank you
              https://lumenia.com/products/street-...as/e-lum-.html...
              02-13-2023, 09:45 AM
