32 samsung lcd will not turn on just blinks 5 times
  • GusShadow
    • May 2014
    • 5
    • Greece
    #81
    Re: 32 samsung lcd will not turn on just blinks 5 times
    Recently I faced the same problem, with one Samsung TV with HANARO-2 power supply, and I would like to contribute a little bit for anyone else facing the same symptoms.
    The TV had sound but no picture.
    With the power supply disconnected from CPU board, the backlight illuminates for a second and then turned off.
    By using the tip of mr. budm above, that said when the RP823 is removed the backlight and TV is working.
    I checked a bit closer the circuitry, and I have remove the J867, this jumper connecting the RP823 with the FAN7530 IC [UP801S], this is much easier to remove.
    I take a measure with a volt meter from the side of RP823 and earth the negative lead of CP809. I measure about 13V, I measure again with J867 in place, and now the meter indication is 0V.
    So no VCC power for the FAN7530 and also no VCC power for the LM393 [UB802] comparator, and finally no INV_UVLO signal.
    I checked the components and soldering of them, as follows [RP823], [UB802] Pin 8, [QB801], [ZB801], [DB802], [RB815], [PC802S], [DM802] , [RM890], [TM801S] transformer pin 5 and 6, there is a cold soldering that make the backlight not to working when the FAN7530 is connected. After the resoldering, the power supply is worked as it should be.
    • ricosavy
      • Jul 2012
      • 457
      • united states
      #82
      I accidently touched two pins on icb801s and looks like it blow resistor rb805 which is a fusible on schematic part number is 10j2w.color codes are brown,black,black,gold,white.i thinking it is a 10 0hm 2watt resistor but i am not sure.
        10 Ohms, J= 5%, 2W.
        • ricosavy
          • Jul 2012
          • 457
          • united states
          #84
          FW20A10R0JA Found this from mouser i think this will work.
            That should be fine, it is fusible resistor. Hopefully nothing else is damaged.
            • ricosavy
              • Jul 2012
              • 457
              • united states
              #86
              It is i think my pfc got damaged i replaced it but still would not work.I found this fusible resistor had blown.I will replace it when it arrives and test it also will replace 8 pin chip that i touched two pins on. I think it is ok but i will replace it when i get it.I believe it is the pwm that feeds the pfc.
              • ricosavy
                • Jul 2012
                • 457
                • united states
                #87
                I put in the fusible resistor measure at main cap i am getting 380 volts.I am still not getting backlights.also i check the ps on voltage it is at .8 volts i touch front power button i get no change.i jumpered the ps-on with 5volts to see if it would come on nothing just power light was on.Any ideas what else to check.
                • ricosavy
                  • Jul 2012
                  • 457
                  • united states
                  #88
                  I did notice i was getting 12.1 volts where i am suppose to be getting 13v on connector going from power supply to main
                    "I put in the fusible resistor measure at main cap i am getting 380 volts." That means the PS_ON must be present otherwise you will not have this boosted Voltage on the main filter cap, so I am sure what you are seeing at the PS_ON pin since PFC is working, also when you jump the 5V and PS_ON did you remove the wire going back to the main board?
                    • ricosavy
                      • Jul 2012
                      • 457
                      • united states
                      #90
                      Yes i did i removed the wire going back to main board to avoid feedback.i removed the jumper put the wire back in the connector.if disconnect main board i will get backlight.
                        "if disconnect main board i will get backlight." That means the power supply and the backlights inverter is working.
                        Then the problem is on the main board that keeps the PS_ON stuck off.
                        So right we are back to the original condition at the start of the thread, main board problem.
                        • ricosavy
                          • Jul 2012
                          • 457
                          • united states
                          #92
                          I removed rp823 it reads 1.6 million ohms
                            Where is this part?
                              OK, I see that now, it is in the PFC Voltage sensing if the PFC boosted Voltage gets too high, it is 1.5Meg Ohms resistor, it is OK.
                              Right now the power supply is not the problem since the backlights do come on.
                              • ricosavy
                                • Jul 2012
                                • 457
                                • united states
                                #95
                                Why am i getting 12.1v where it says i am suppose to be getting 13v
                                  It is not tightly regulated power supply and it does not have to be since it is used for the Audio power amplifiers which does not required regulated Voltage to work.
                                  • ricosavy
                                    • Jul 2012
                                    • 457
                                    • united states
                                    #97
                                    I well at least we know i have a bad main board for some reason it is not supplying ps-on signal.i will try to trouble shoot it it is hard since there is no diagrams available for the main board and all the regulator seem to be working.there is only on chip with heat sink maybe i need to put some hot air on it see if it has any effect on main board.
                                    • ricosavy
                                      • Jul 2012
                                      • 457
                                      • united states
                                      #98
                                      It seems like lot people have same problem with this model.
                                      • robwigglezz
                                        • Jan 2015
                                        • Unites States of America
                                        #99
                                        I was hoping that after 4 hours of reading I could have bought a 2 dollar part and been done with this TV.
                                        Mine will randomly power on and function like normal if I pull the power plug from the back and plug it back in. (Maybe it's something simple, but I couldn't find anything similar)
                                        I get 12.24v for all 13v pins and 5.24 for all 5v pins. Same results connected or disconnected from the other board.
                                        • ricosavy
                                          • Jul 2012
                                          • 457
                                          • united states
                                          #100
                                          There got be fix for motherboard there is people out there offering repair service
                                          • Nairolf
                                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                            by Nairolf
                                            I have a Samsung DM32D display.
                                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                            Here’s what I have tried so far:
                                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                            Yesterday, 03:47 AM
                                          • Egidio85
                                            Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                            by Egidio85
                                            Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                            the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                            the fan does not start.
                                            I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                            any advice on what to check?
                                            06-10-2025, 05:00 AM
                                          • brithepi2k
                                            Samsung UE75TU7020k No picture, Standby blinks 2 times
                                            by brithepi2k
                                            My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                            04-23-2025, 10:05 AM
                                            09-07-2024, 05:50 AM
                                          • Msb1xr
                                            Have to turn on 77” LG C1 multiple times to get to come on
                                            by Msb1xr
                                            Have to turn C1 on and off multiple times for it to fully come on
                                            Have to run LG C1 on multiple times for it to fully work
                                            If I have it off for a while I have to turn the TV on and off and handful of times for it actually display what it's suppose. The times it doesn't nothing comes up like the input or dobly vision logo. Once it's on I can turn it off and back on fine and the picture looks perfect.
                                            Unhooked everything except antenna. Reset tv to factory settings. Let it sit and when I tried 2hrs later turned TV on and sound comes through but no picture....
                                            10-13-2023, 04:09 PM
