Samsung-LE32B530P7W-Intermittant Back Light
  • AlbertRoss
    • Jul 2012
    • 181
    • United Kingdom
    Hi All,
    Purchased this Sammy as a spares or repair. Previous owners said it would work fine for around two to three days and then the screen would go blank but sound is still there. No matter how many times it was turned on, the screen would still be blank. Leave it for a few days and it returned to normal.
    Anyway, It all came to life when I fired it up with no problems, perfect picture, sound, everything ok for a few days until now. It turns on, has sound but no back light, changes channels ok either on the set or by remote. Performed various 'wiggle' tests here and there thinking it's a loose connection or something but, no luck.
    I'm stuck now where to check next as I'm not sure what powers up the back light?
  • randtek
    • Oct 2011
    • 280
    • US
    Re: Samsung-LE32B530P7W-Intermittant Back Light
    An easy check is to unplug the TV, disconnect the cable going from the main to the power board. then plug the TV back in.; The backlights should come on and stay on with that plug disconnected. This will confirm or eliminate the main board as the source of the problem.
    • AlbertRoss
      • Jul 2012
      • 181
      • United Kingdom
      Disconnected cable going from main to power board, turned TV on, backlights stayed on for approx,. 15s and then turned off. Tried it with cable connected, does same thing but now I have sound. What actually operates the backlights?
      • selldoor
        Slow Learner
        • 7870
        When it is on with a source and the sound is on can you see a very dark image on the panel - sometimes shining a torch onto it at various angles can help.
        Next You will have to try and get to the Tcon. The Tcon will be under that middle panel where the orangyred flat cable goes. In fact you should try and remove clean and reseat it , then try the tv again.
        Looks like the inverter transformers are on the power supply but cant see the plugs for the lights - can you take the power board off and do a picture of the underside there may even be another board under it?
        • AlbertRoss
          • Jul 2012
          • 181
          • United Kingdom
          I can see a very dark image moving around on the screen when using a flash light. Have removed the T-Con board, connectors look ok, although I don't have any special cleaner. Removed the PSU, no more boards underneath it.
          Re-installed components, turned on TV, back lights went off at around 60s.
            Closer pic of here if possible please.
            • AlbertRoss
              • Jul 2012
              • 181
              • United Kingdom
              Is this o.k?
                Perfect picture, I wish all pics on this forum were like that.
                OK pin 23 is your on/off pin. Can you check this with PSU installed? Is it stable or switching off when the backlight goes off?
                • AlbertRoss
                  • Jul 2012
                  • 181
                  • United Kingdom
                  When back light on, pin 23 reads 2.12V stable. When back light turns off, same reading. I'm checking this with the PSU cable to main board disconnected.
                  • selldoor
                    Slow Learner
                    • 7870
                    I am pretty sure it needs to be connected up
                    Still couldnt see the lamp connectors is it hard to get the board off that frame at the bottom.
                    Inverter transformers look a bit different to ordinary Darfons. I have marked what I think are relevant pins on attached.
                    Meter on Ohms 200 or 20 if you have it measure P1 >P2 then meter on ohms
                    2000 test S1>S2 and S3>S4. Then repeat on other transformer.
                    Post results as
                    T1
                    P1>P2 = xx ohms
                    S1>S2 = xxxx ohms and so on
                    • AlbertRoss
                      • Jul 2012
                      • 181
                      • United Kingdom
                      Regarding your previous question, I re-connected cables and checked voltage on pin 23. This time I had 4.46V stable with backlight on or off.
                      Now I'll get back to the remaining question.
                      • AlbertRoss
                        • Jul 2012
                        • 181
                        • United Kingdom
                        Ok,
                        T1 (T1801)
                        P1>P2 = 009.1R
                        S1>S2 = 0.833K
                        S3>S4 = 0.836K
                        T2 (T1802)
                        P1>P2 = 009.1R
                        S1>S2 = 0.836K
                        S3>S4 = 0.836K
                          So main board isn't shutting backlight off. Check 13V pin on board.
                          Odd design. Looks like the big transformer on the board drives the other two transformers. Is there a part # such as BN44-xxxxxx that could be used to get schematics?
                            Never mind. 'twas staring me in the face. Schematic:
                            http://www.tgohome.com/ServiceManual...g_BN44-00261B_[SCH].pdf
                            • selldoor
                              Slow Learner
                              • 7870
                              Originally posted by AlbertRoss
                              Ok,
                              T1 (T1801)
                              P1>P2 = 009.1R
                              S1>S2 = 0.833K
                              S3>S4 = 0.836K
                              T2 (T1802)
                              P1>P2 = 009.1R
                              S1>S2 = 0.836K
                              S3>S4 = 0.836K
                              Both look good individually and relative to each other.
                              Do you have any spare ccfl bulbs old panel/laptop screen etc
                              • AlbertRoss
                                • Jul 2012
                                • 181
                                • United Kingdom
                                Pin 21 = 12.75V. Pin 22 is also a 13V ref, this reads 12.75V.
                                • AlbertRoss
                                  • Jul 2012
                                  • 181
                                  • United Kingdom
                                  I don't have any spare ccfl bulbs. I do have another Sammy but can't use it for spares as I've just repaired it.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    If you can get to the lamp connectors you can do the one at a time flash for each bulb. Disconnect all but one and see if it flashes and try and guage if they all flash the same brightness and colour.
                                    Can you also check the fuse next to the Big Cap and the voltage across the Big cap when it is just plugged in and when you have pressed the power button
                                    High voltages for these tests when doing the lamps un plug from mains and let it stand for 5 minutes between each test. 600-800Vac
                                    Big Cap test could be 400VDC
                                    • AlbertRoss
                                      • Jul 2012
                                      • 181
                                      • United Kingdom
                                      Fuse o.k. 000.2R. Voltage across big cap when just plugged in is 326.2V. Switch on TV, voltage rises to 344.2V.
                                      I've tried lifting the long black connector that fits onto the lamps inside the panel but have a feeling they might break if I'm unable to hold them. Hope this makes sense?
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        1 First voltage is ok - second may be a bit on the low side.
                                        2 Probably does make sense - but doesnt mean anything to me - perhaps Tom or the others have seen something similar.
                                        Not sure where to go next are there no wires between the power/inverter board and the lamps, that you can unplug?
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
                                        • dronerat
                                          Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                                          by dronerat
                                          Hi Guys,
                                          This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                                          PSU: L48S6 FHS BN44-00807D
                                          T-Con: BN95-01937A
                                          Panel: CY-GJ048HGLVLH
                                          MB: NA (Currently as the TV is assembled and forgot to take picture)
                                          As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                                          It was sent to an authorized service for repairs and returned with the...
                                          05-15-2020, 08:03 AM
                                        • rp93
                                          2018 Mac Mini A1993 LogicBoard 639-06830 No boot,Blank display,Fan blasts briefly
                                          by rp93
                                          I am trying to troubleshoot my 2018 Mac Mini. It all of a sudden would not respond/wake up. So i turned it off and turned it back on. When I power it up, the fan blasts hard for a second, then shuts off, power light may go off, then back on, sometimes blasting the fan again. It does this a few times then eventually(sometimes) the power light stays on and the fan runs at a normal speed, but with no HDMI/display. Nothing ever shows up on the display.(no sound, no chime, checked wifi router to see if it trys to connect, which it does not)
                                          I have the Mac Mini completely disassembled...
                                          12-04-2023, 06:51 PM
                                        • koby058
                                          vostro comes up with back light but no picture
                                          by koby058
                                          Hi people!!
                                          The owner said it showed bad picture once in a while (attached)
                                          I see that there is back light but no picture.
                                          I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                          Also attached schematic and BDV
                                          LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                          07-13-2025, 01:03 PM
                                        • kca
                                          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                          by kca
                                          Hello all ~
                                          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                          No picture. No sound.
                                          I tested all the voltages coming out of the power supply...
                                          10-12-2023, 05:23 PM
