Emerson LC401EM2F
  • lilmonk3
    • Apr 2012
    • 259
    Re: Emerson LC401EM2F
    Thank you for the help Budm
      It is blowing the main fuse the minute you plug it into the outlet?
      Please check the resistance reading (meter set to Ohm mode 200 Ohm range) for me as noted (board not installed or plug in).
      • lilmonk3
        • Apr 2012
        • 259
        I have an auto ranging DMM.. I have ohm and diode setting... No 200 ohm.. Which one would you like me to use.. I did just do some quick checking with it in diode mode and D1604,D1606 read 000 both ways, D1607 reads .488 and .493
        • lilmonk3
          • Apr 2012
          • 259
          And yes it blows the the fuse as soon as its plugged in if all boards are connected.. But if I unplugg the flat white ribbon cable that goes from the PS to Mainboard the fuse does not blow
            OK, please check the resistance of the Diodes I red-lined in picture 1 & 2 tell me what you get.
              I am unsure on whether this is based on a self-resonant topology or not. It looks like it might use a controller IC. However, I was playing around with a real cheap wall wart today which used a self resonant circuit. When I shorted the output, it blew the mains fuse! So some of these self-resonant designs don't cope well with shorted loads.
                Set meter to Ohm mode, auto range is fine, we are looking for shorted parts which will no longer act like semiconductor any more, it will read low Ohm in both directions.
                Again, take the reading of the bad part off the board when it shows bad on the board to verify, you can just lift one leg off the board and take the reading also.
                This power supply uses dual PFC circuits. The two MOSFET's may be shorted out, the B+ to the PFC is supply through the relay, so if the main is not connected, the PFC will not get any power to it, which is why it did not blow the fuse when main board is connected, the 5VSTBY SMPS is before the relay so it is always running with its own rectifiers which is OK since it did not blow the fuse.
                I cannot see the number too well in the pictures.
                Where are the D1604,D1606? Are they in the second pictures? the group of 4 in the bottom left of pic#2? My eyes are not that good.
                This is what I come up with. The MOSFET or DIODE for the PFC may be shorted, or MOSFET for the SMPS may be shorted also.
                • lilmonk3
                  • Apr 2012
                  • 259
                  Ok here are the readings of the diodes in pic 1 and 2 with one leg lifted..
                  D1201 OL 4.60
                  D1202 OL 4.90
                  D1203 OL 4.39
                  D1204 OL 4.21
                  D1604 00.3 00.2
                  D1606 OL 2.94
                  D1607 OL 4.84
                  D1608 OL 4.73
                  D1609 OL 5.26
                  D1610 OL 5.05
                  I marked up the board in the pics below .. My eyes are not very good either
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    D1604 00.3 00.2
                    D1604 is bad if that is tested out of circuit.
                    --- begin sig file ---
                    --- end sig file ---
                    • lilmonk3
                      • Apr 2012
                      • 259
                      Thanks retiredcaps. Its sf38 .. Looks like I will have to order online.. Was hoping Ratshack would have something I could use just to get by.. Oh well
                      • lilmonk3
                        • Apr 2012
                        • 259
                        Do I have to stay with the exact spec of this diode.. I would LOVE to be able to run to ratshack to get a part that will work.. I am wanting to try to see if I can get this thing going by monday. My nephew is home from college for the holiday weekend and I wanted to give this TV to himm.. Any chance that ratshack would have something that would work??
                        Its a SF38,DIODE, ULTRA-FAST, 3A, 600V
                        • lilmonk3
                          • Apr 2012
                          • 259
                          http://www.radioshack.com/product/in...ductId=2062579
                          Would that work and be safe to use???
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #33
                            Not read if it is ultra fast but it is only 400v not 600 spec sheet attached
                            maybe ok for testing but I dont really know.
                            Perhaps other will know for sure.
                            Edit
                            Not even fast let alone ultra so if its in the PFC circuit I guess its no good.
                              Please check Q1602 as shown in my drawing also, just to be sure it is not damaged.
                              just label the pin as 1, 2, 3. Then using Ohm mode and report the readings:
                              1 & 2 =
                              1 & 3 =
                              2 & 3 =
                              The Diode should have at least the same Voltage and current rating.
                              The Vf must be equal or less.
                              The Trr must be equal or less
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #35
                                Re SF38,DIODE, ULTRA-FAST, 3A, 600V
                                Have you no other boards knocking about you could borrow one off?
                                Is this the nephew with the westinghouse - what happened to that?
                                • lilmonk3
                                  • Apr 2012
                                  • 259
                                  Sell.. Yes its the same nephew.. The westinghouse is still here laying on the bench.. With school starting , I have not been able to sit down and mess with it.. Its sitting there for a raining day I started to mess with it the other day, but got frustrated because of all the pulled pads, and I am not smart enough to figure out how to fix em .. I am going to dig around on some old boards today and see what I can come up with..
                                  • lilmonk3
                                    • Apr 2012
                                    • 259
                                    Do I have to say with the the 600V or can I go a little lower if I find one on a board that isnt the exact same specs.?
                                      In its location, you may be able to use 400V.
                                      • lilmonk3
                                        • Apr 2012
                                        • 259
                                        I found an old board and it has some IN5406 BL on it.. No sure what the BL means , but the datasheet on IN5406 is 3a 600v... So I will give it a try.
                                          In that position (if it is rectifying 50/60Hz AC), that diode is perfectly fine.
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
