Quick Resistor Value Question
  • lilmonk3
    • Apr 2012
    • 259
    I am working on a Hitachi RPT for the local vet club, it has a the standard convergence issue.. But before I jump and buy the ICs that may need changed, I noticed a resistor right by one on the ICs that is burned a bit.. I would like to replace it first just to see if thing in prove... Its a 1.5ohm 1w.. I have a 1.8ohm 1w... Can I use this 1.8 instead of ordering a 1.5???
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Quick Resistor Value Question
    should be ok if the original resistor has a 5% tolerance might be somewhere near it
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • lilmonk3
      • Apr 2012
      • 259
      The service manual states that its 5% and that what mine 1.8 is ... Thanks
      • truep
        • Aug 2010
        • 373
        Be aware that there several low value resistors in the area that should be checked. These are flame proof resistors and must be replaced with the same type for safety.
        • lilmonk3
          • Apr 2012
          • 259
          Yep its flame proof.. Thats what I got from another project, just 1.8 instead of 1.5..
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • mikey5791
            Need help to replace burned resistor in 350w atx psu
            by mikey5791
            Hi to all forum members,
            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
            12-26-2024, 04:55 AM
          • MidnightRoller
            Can a resistor lose resistance after hot air?
            by MidnightRoller
            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
            02-02-2022, 11:46 PM
          • artvandalai
            What resistor ohm will work better to repair this waterpik?
            by artvandalai
            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
            01-05-2025, 04:10 PM
          • chth96
            Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
            by chth96
            I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
            Since then, This AC/DC adaptor have been out of order.
            But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
            After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
            And Is there any possibility that it will suddenly explode as well as to be out...
            12-03-2023, 04:40 AM
