I got the thing to work by changing out the u7 chip on the main board. Now here's the wired thing. When you first turn it on it will work fine for about 30 minutes. Then it will loose video but keep the backlight. You have to unplug it to turn it off. After its been on and looses video you can plug it in 5 minutes later and i t will work for about a minute then loose video again. U33 voltage if fine during all this. U7. Is outputing 1.5 volts when its working but when it loosed video it drops to 1.1 volts but the backlight stays on. I am going to replace u7 but want to know of there is anything else I should look at?
new problem, new thread. vw42l
Re: new problem, new thread. vw42l
Perhaps the video processor is freezing up. Try checking the video processing board for bad caps, and check the voltage regulators on the board too. Did you figure out what u7 powers? Does it get very hot?Muh-soggy-kneeComment
What does the sound do?Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Too late now but you should have kept on with the old thread - I havent the time to jump from one to the other can you copy the any pictures forward. Is the U7 fed by another regulator - check that when the set is working & non working.Please upload pictures using attachment function when ask for help on the repair
by alro7779Hello, everyone!
A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,... -
by SpikemanHi, I'll tell you the story of this PC.
The PC was repaired because it had a shorted power supply. What happened was that the plastic covering the buffer battery positioned by the manufacturer on the capacitor melted, thus generating a short.
After the repair, the PC worked, I installed Windows 11 and I may have had some problems with the video drivers, but after a bit of tinkering I think I solved them.
However, the PC later presented the problem in the video shared very frequently.
The problem also occurs at startup, in the bios and when using it as a monitor thanks...-
02-27-2024, 10:17 AM -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... -
by zimeyhHi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
by hugocarmoHi everyone.
I have the following problem.
I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720,... - Loading...
