Philips 32FD9954 plasma - worth $50?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I have the opportunity to pick up a Philips 32FD9954 plasma TV for $50 described as no power. This is an older plasma, it's just 1080i (1024*856). A little googling around reveals it has a design flaw in the PSU, bad caps and PWM controller failure being common. Looks like a cheap fix.
    What do you say? This will be my first plasma repair btw.
    A working TV? How boring!
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Philips 32FD9954 plasma - worth $50?
    Go for it!
    If you cant fix it, then you can always sell the working parts
    Muh-soggy-knee
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Not a large market for plasma parts here i'm afraid. I'm waiting for tom66 to chime in.
      I wouldn't really like to have to swallow the cost, and i have another set for the same money, it's a Samsung SlimFit 32" 100Hz widescreen CRT. That's 100% a cheap fix and there's still a market for them (could sell it for $130 easily), but i would prefer the plasma though, because the tube would be an absolute b*tch to move at that size.
        When plugged in - does it emit a loud buzzing? (Like a shorted iron-core transformer) IF SO RUN AWAY QUICKLY! Panel is cracked. Quiet buzzing is okay.
        Also, try and see if you get any flickering from the panel when plugged in. If so panel is okay.
        You will need a scope to debug a plasma beyond replacing random parts.
        Plasma panels use voltages of around 200V DC but that's not alien to you is it .
        You're dealing with an earlier generation of plasma panels. Before crappy LG and Samsung ones flooded the market. It looks like a NEC or Fujitsu panel. It also looks like it has an IPM (big power module, lots of semiconductors on one chip); if that's dead, it could be tricky...
        http://www.interliquidparts.com/wp-c...18107-5017.JPG
        I would say, go for it.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          It does not buzz at all, it simply doesn't start. No standby LED, nothing. Seller told me there was a repair attempted on the PSU with no success, but other than that the TV is in one piece and no boards are missing.
          Hopefully the 2x 10MHz one i currently have will do.
          Mkay... Will make a decision tonight.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Well, it seems the PSU is at fault in this, and ofc, I know how much you love PSUs
            Muh-soggy-knee
              I generally stay away from TVs which have had work done on them before because you can't be certain what has been fiddled with.
              On an SD/part HD panel, sure. No problem. I used a 20 MHz dual channel one on a 1080p set. It was a challenge, but it just about worked enough for me to see the sustain board was okay.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Why run if it makes a loud buzzing sound? Does it mean the panel might shatter?
                Muh-soggy-knee
                  When the screen cracks, you get shorted electrodes. The buzzing is the sound from the PSU and sustain boards being shorted out. No, there is no safety hazard - I was referring to the fact that you shouldn't buy it .
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Ah, lol!
                    Our 42" sammy makes buzzing noises from the sustain boards, the TV has been working fine, so I just think its normal. You especially can hear it if you go from a black screen to a light color screen.
                    Muh-soggy-knee
                      Ah, lol!
                      It's loud buzzing. Quiet buzzing is okay. Loud buzzing like a big iron transformer in distress.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        Me too... On the other hand, that Sammy CRT has never been messed with, but again, it would be a complete hog to move around.
                          How certain are you the Samsung CRT hasn't been fiddled with?
                          I'm surprised that CRTs are still popular in Romania - I suppose they are older models? - LCDs are now cheaper than CRTs were a few years back. Case in point my dad got a 28" JVC CRT (made in UK - suspect it is a Toshiba chassis) for ÂŁ300 about 6 years ago (still going well) but you can now buy 32" LCDs for ÂŁ250 (good Panasonic Viera LCD 32".)
                          • indel
                            • Aug 2012
                            Th3 uN1Qu3,
                            You are my best bet in helping me with an IT question. I am visiting my friends in Bucharest, in September, and I intend to bring, to each of them, a mini-tablet Nexus 7. Can you tell what kind of router should I bring, too, to be sure that they can use the tablet? Here, in Houston, I am using a cable modem and a Linksys wrt54gs. I assume that they have either DSL or cable.
                            Thanks in advance,
                            Indel
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              100%. The ad has been up for a while (i think i first saw it 2 months ago), and it's simply described as "no longer turns on, did not attempt to repair it". The seller appears to have no electronics experience.
                              They still dirt cheap CRTs in supermarkets for one, and secondly, the SlimFit type tubes are still sought after - people's biggest gripe with CRTs is their size, slim ones are okay.
                              Originally posted by indel
                              Th3 uN1Qu3,
                              Thanks in advance,
                              Indel
                              Cable modems are almost extinct here. You can still find DSL here and there, but it's not common. Only with Romtelecom ISP, which sucks, so a lot of people have moved to better alternatives.
                              Anything with an ethernet port on it will work. Even if they got DSL you would simply plug the ethernet cable that comes from the DSL modem into the router instead of the PC.
                                In the UK, 1024x824 pixels is considered HD Ready. 720p plasmas are 1024x768 (42" and below - 50" models are 1366x768.) Only thing is, I doubt it will have HDMI... does it have DVI though?
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  No HDMI indeed, just component. It has 2x VGA and one DVI-D.
                                    Sounds nice, would you keep it or sell it?
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      I have nowhere to put it... i'll likely sell it. Thing is, i'll be leaving for my grandparents' place at the seaside shortly, and there i have room, and i'm sure grandpa would enjoy football and boxing on a big screen, so if i get it there i may keep it.
                                      The TV isn't in my city, so i'll have to pay shipping anyway, i get to choose where i have it delivered. The Samsung CRT on the other hand, i can get to see locally, so i still don't know which one to pick.
                                      • celiabrown
                                        Issue with Plasma Philips 37inch chassis FTL2.1
                                        by celiabrown
                                        Hello guys,
                                        My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                        Can someone has any symptom like this ?
                                        Thanks​
                                        05-09-2024, 10:56 PM
                                      • alro7779
                                        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                        by alro7779
                                        Hello, guys!
                                        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                        09-14-2025, 12:25 AM
                                      • G33RT
                                        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                        by G33RT
                                        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                        It does power up when pressing the power button.
                                        I already try the power button while plugin the plug with no result.
                                        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                        Could this be an PSU or eMMC issue ?
                                        07-19-2025, 03:43 AM
                                      • double_DD
                                        Philips curling iron - is this a common AC cable?
                                        by double_DD
                                        Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                        As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                        Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                        08-18-2025, 10:04 AM
                                      • janos6662000
                                        Philips 47PFS7509/12 LCD TV problem
                                        by janos6662000
                                        Hi
                                        I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                        When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                        I downloaded original firmware and applied the update, but the problem remained.
                                        From a colleague i received a "factory package software" which is a lot bigger.
                                        I made another firmware update, but still did not solve the problem.
                                        Somewhere on the way the error got worse, because at the moment the...
                                        08-12-2025, 12:54 PM
