I have this HPR5052X just replaced the X-SUS Board when it first came on it had black speckles but it cleared up and worked fine for a day or two now the picture goes black then comes back and now staying black more often. I've already tested all of the voltages according to the sticker and and made very minor adjustments with no change to the TV condition. Also I can hear a buzzing/humming sound coming from the X-SUS board and when it's not making the sound the picture is fine. Could it just be I have ordered a bad board?
Samsung HPR5052X Plasma goes in and out
Re: Samsung HPR5052X Plasma goes in and out
What was the original fault, before the X-sus was replaced?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
My brother gave me the tv cause he said it stop working, when I plugged it in you could hear the Samsung start up Chime but wouldn't get a picture. I then tested all of the fuses and one was blown. The one on the X-SUS board. I read if the fuse was blown not to replace it cause it meant the board was bad, thus me ordering one.Comment
Sometimes the fuse can blow without cause so I always replace it. Worst case it blows again and you buy or repair the X sus. Did your brother mention the TV having the flickering fault before it went out?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Okay, so the X sus was probably failed in the first place. It sure sounds like your new one is dodgy, you should send it back and get a refund, then try another one. Do you have a DMM (digital multimeter?)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
There should be a sticker on the plasma panel saying what the voltage should be. What does this show?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Okay, I would try another X sus board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by CooperrI picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board... -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
The models launched in 2018 and 2019 respectively.... -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
• Have obtained Samsung schematic & service documents - Can upload if helpful.
• Have read ALL applicable threads
• C1818 and CP820 replaced as low hanging fruit
• CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
• VCC pin (18) of PFC... - Loading...
