Dead Sammy - LE26B450C4W
  • AlbertRoss
    • Jul 2012
    • 181
    Hi Guys,
    T.V. has no power indicator light, no clicking noise, no sound, no picture, just dead! Both fuses o.k. Have 240VAC across fuse FS801S, what kind of voltage should I expect to have on the second fuse FM802S? What would the next step be to check? Apart from throwing it the dumpster! Have included some photos, can take some more if required.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Dead Sammy - LE26B450C4W
    I would go for testing the at the BIG Cap. With it plugged in and switched on, Meter on volts 600 DC put red lead on positive leg and black lead on negative leg - polarity is important CARE high voltage & do not touch any heatsinks.
      Check to see if you have good standby voltage. If unsure post a closer picture of the connector going from PSU to mainboard.
      • AlbertRoss
        • Jul 2012
        • 181
        326.3 Vdc on BIG Cap (CP815)
        Pin configuration PSU to Main Board (1 to 15)
        1. PWR_ON/OFF
        2. STBY 5.3V
        3. GND
        4. 13V (s)
        5. GND
        6. GND
        7. 5.3V
        8. 5.3V
        9. GND
        10. 13.5V (m)
        11. 13V (m)
        12. Inv_ON/OFF
        13. E-PWM
        14. DET_5V
        15. N.C
        Except for the GND pins, I have unstable readings on all others (fluctuating voltage)
          This points to a bad startup capacitor, or shorted output diode.
          This power supply looks like it combines standby and main supplies. Inverters are run off the +400V bus.
          My suggestion: Replace CM808, the yellow and brown caps, and the other small brown cap near the blue capacitor.
          • AlbertRoss
            • Jul 2012
            • 181
            Found the CM808 as in the enclosed picture but having trouble finding the other one's you've mentioned without the numbers? I have a capacitance meter to check when I find the others.
              These.
              Cap meter might not show bad ones (ESR meter necessary), but give it a go.
              • AlbertRoss
                • Jul 2012
                • 181
                CM808 is a 50V 22uF, when checked on board: 23uF
                CP809 : : 50V 47uF : : : : 38.5uF
                CB804 : : : : : : : : 3.8uF (yellow cap)
                CM804 : : : : : : : : 50.2uF
                Looks as if I have some bad capacitors? Is it worth checking off of the board? Who would you suggest I purchase the caps from in the UK?
                  Looks like it. Farnell is a good source. And for small caps, eBay can work.
                  • AlbertRoss
                    • Jul 2012
                    • 181
                    Thanks for your time and help, just having a look around e-Bay and Farnell.
                      Let me know if you need any help, may be able to order them cheaper via contract pricing.
                      • AlbertRoss
                        • Jul 2012
                        • 181
                        Now I'm not to sure as I've removed CB804 from the board and checked it on my capacitance meter. On the board it read 3.8uF, off the board it's reading 51.0uF?
                          With high ESR, cap will sometimes read much larger. Your meter is optimised for caps with near zero ESR. I would say that it is a clear sign something is wrong.
                          • AlbertRoss
                            • Jul 2012
                            • 181
                            So the $64,000 question is, do I just go and replace most of the electrolytic caps which should only cost a few pounds anyway? At least they will be taken out of the equation.
                              If you like. Use decent quality caps, like Panasonic FC/FM/FR.
                              • AlbertRoss
                                • Jul 2012
                                • 181
                                Awaiting delivery of the capacitors, will keep you posted.
                                • AlbertRoss
                                  • Jul 2012
                                  • 181
                                  Have replaced the caps as circled in the previous reply/picture. I've not replaced any other components, The standby light flashes on/off which I would say, looks a bit dim? No picture, no sound, no clicking sounds and no response from the on/off switch or remote. I have some spare caps the same as I've replaced but not the 1200uF 25V or 1200uF 10V.
                                  I'm a bit stuck now as what to check next?
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    Check that you put them in the right way round then re test the voltages on the out socket. When doing the poweron cycle the on/off switch
                                    • AlbertRoss
                                      • Jul 2012
                                      • 181
                                      The caps are installed correctly. I'm checking on the 1st pin of the 15 pin socket, which is PWR-ON/OFF, no voltage change when on/off switch operated. As before, I have fluctuating voltage on the remaining 14 pins (except gnd) Makes no difference voltage wise if the 15 pin is connected/disconnected.
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        Sounds like either the mainboard is dead, or there is no standby supply going to the mainboard.
                                        Muh-soggy-knee
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
                                        • FiguringITout
                                          MSI Raider GE75 - Not posting, probable dead CPU
                                          by FiguringITout
                                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                          07-25-2024, 07:27 AM
