Sony Bravia KDL-40D3100 - Doesn't Turn On - Standby Light Blinks 8 Times
    Re: Sony Bravia KDL-40D3100 - Doesn't Turn On - Standby Light Blinks 8 Times
    Originally posted by 386
    Yup, tested and retested with my meter, no signs of any current flow.
    OK. Does it still do 8 blinks?
    • 386
      • Jul 2012
      • 30
      Yup, still the exact same error.
      Also, I just tried disabling pins 5 - 8 on CN4001 (AU_13V and AU_GND), which can be seen on page 34. Just experimenting, it didn't effect the error/behaviour.
      I've also noticed on page 25 there's "AU-PROT" on the top right hand side, which is meant to connect to BU board via CN1001? I can't locate the that connector? Am I missing something? Also, sorry if I'm searching totally off track here. Thanks again
        Unfortunately the "BU" board is "too complicated" for technicians to service. It must be replaced only. What a load of crap!
        • 386
          • Jul 2012
          • 30
          Wait, does the "BU board" (on page 25) mean the BG1 board? Since I couldn't locate the BU board, I did a google image search for "BU board tv" and nearly all the results seem to be of boards which look like the main BG1 board from this model. In which case where on earth is the CN1001 connector? Is that possibly a typo or from an earlier schematic?
          Edit: Yet, it says that the diagram on page 25 is of the BG1 board, and it has the CN2000 connector to the speakers on the diagram, which is correct on my actual board. But I've looked a number of times for the CN1001, and a board stamped with "BU", with no luck. Maybe I'm going blind, haha.
            Can we see a picture of inside of your TV - all the guts. I have a feeling the BU board will have video processing on it ("Bravia Engine" or whatever they call it.)
            • 386
              • Jul 2012
              • 30
              Unfortunately it's currently night time here, so it was difficult to get enough light for particularly good photos, but here they are anyway:
              https://dl.dropbox.com/u/51809914/Ev...20IMG_3789.jpg
              https://dl.dropbox.com/u/51809914/PS...20IMG_3790.jpg
              https://dl.dropbox.com/u/51809914/In...20IMG_3794.jpg
              https://dl.dropbox.com/u/51809914/BH...20IMG_3796.jpg
              https://dl.dropbox.com/u/51809914/Tu...20IMG_3797.jpg
              https://dl.dropbox.com/u/51809914/UT...20IMG_3800.jpg
              The linked images are slightly higher quality than the ones uploaded directly to the forum, as the forum converts them to smaller size. If you'd like a close up photo of any particular section, or of one of the other sides of a PCB, just let me know
                I'm thinking it's either of the other two green boards. The board in the middle, I suspect that's the 100Hz motion interpolator. The board near the top is possibly the main processor, although it may be the digital tuner.
                You can try unplugging the top digital tuner board and seeing if that works.
                But other than that, I'm not sure where to go from here, other than suggesting random board swapping.
                • 386
                  • Jul 2012
                  • 30
                  I believe the green board in the top right corner to be the tuner. It's labelled DTAU2MB, and the daughter board sitting on top of it is DTAU_FE. One of the first things I tried was powering up the TV with various boards disconnected, all combinations seemed to leave the 8 blink error. Apart from disconnecting the CN4002 connector (on BG1 board), which resulted in the standby LED giving two blinks, which indicates an issue with the 12v power supply, which makes sense. But, apart from that I've been unable to modify the error/response at all.
                    The digital tuner appears to be an OEM, non-Sony part. Makes sense that they would order one in for different countries.
                    With how the TV is currently set up, I'm guessing you can't probe the trace you cut on the bottom?
                    • 386
                      • Jul 2012
                      • 30
                      Not with everything connected/with power on.
                        What is the part # on the BG1 board, if any? Maybe it is available cheap.
                        • 386
                          • Jul 2012
                          • 30
                          Is the part number the number just below where it says BG1 on the previous photo?
                          https://dl.dropbox.com/u/51809914/IMG_3742.jpg
                            That's probably it.
                            I found a similar part but for the UK model. Hence it has SCART etc. It was £24.99. However, no luck with your particular board.
                            If you can find a TV with a smashed screen, the main board may be cannibalised.
                            • exsonyexpert
                              • Feb 2012
                              • 20
                              #54
                              if 12v is present to bg1 probably u have a problem 12v regulator found on the bottom of ur bg1 near speaker terminal i already edited the test point of ur bga but i dont know how to post
                              • 386
                                • Jul 2012
                                • 30
                                To add an attachment:
                                Just below the reply section, click "go advanced", then on the next page you will see the section "Additional Options", in that section click "Manage Attachments", this will open an attachments window, browse for your file, then click the Upload button. It will take a little bit of time to upload, then post normally.
                                Alternatively, you can upload your file to an external third party website, and just share the link with us. Thanks for any help
                                • 386
                                  • Jul 2012
                                  • 30
                                  Tom, could you please link me to that part anyway? It's a possibility I guess. Cheers for all your help!
                                    I will try and dig it up.
                                    • 386
                                      • Jul 2012
                                      • 30
                                      Any luck finding that link, Tom?
                                      Also, if anybody else has any other ideas on how to fix/diagnose the problem, or where to buy parts from, please let me know!
                                      • Jasman
                                        • Jan 2015
                                        • Portugal
                                        #59
                                        Hello, sorry to be digging up old posts but can anyone please repost the service manual, because the ones linked in this post are ofline.
                                        Greetings from the Azores
                                          • 12323
                                          • U.S.
                                          #60
                                          http://www.toms-service-manuals.com/...h=Submit+Query
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
                                          • androripara
                                            Sony Bravia 55HX820 - 4 times blinking red standby led
                                            by androripara
                                            i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
                                            I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
                                            Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
                                            10-19-2023, 05:16 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • Elecfronicsssss
                                            DA0NJJMBAG0 charging light blinks
                                            by Elecfronicsssss
                                            Laptop motherboard DA0NJJMBAG0
                                            PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                            CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                            GUIDE ME WITH THE PROBLEM..
                                            SUMMARY-
                                            1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                            2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                            05-12-2025, 02:32 AM
