Sony Bravia KDL-40D3100 - Doesn't Turn On - Standby Light Blinks 8 Times
  • 386
    • Jul 2012
    • 30
    Hi, I'm just wondering if anybody might be able to help me diagnose an issue with my Bravia KDL-40D3100.
    When the power button is pressed, you can hear the sound of (what I assume to be) a relay click, but the screen never lights up, and the standby light just blinks red 8 times. What does error code imply?
    How can I further diagnose the issue? Is there a certain board I can simply replace?
    Also, I'm competent with a soldering iron, and have a multimeter.
    Thanks very kindly for any assistance,
  • 386
    • Jul 2012
    • 30
    Re: Sony Bravia KDL-40D3100 - Doesn't Turn On - Standby Light Blinks 8 Times
    I've located the service manual, and the error appears to be in relation to the audio circuit.
    I've checked all the internal connections, and everything looks pretty clean in there. Still no luck. There's no obviously burnt out components that I can locate. I'm assuming the fault is probably on the BG1 board, as it appears to contain all the audio circuit. Any suggestions as to where I could buy a spare BG1 board from? Kind regards
    Any other ideas?
      If you unplug the BG1 board, does it power up?
      How about a picture of this BG1 board?
      • 386
        • Jul 2012
        • 30
        I took some photos of the BG1 board:
        https://dl.dropbox.com/u/51809914/IMG_3742.jpg
        https://dl.dropbox.com/u/51809914/IMG_3746.jpg
        If you'd like other photos, or better photos of particular areas, just let me know.
        Also, I've tested both speakers, and both are working correctly.
        Oh, and here is the service manual: http://www.mediafire.com/view/?0jn6t0qt00p6n0k
          There are several fuses, e.g. F4005 that are marked on the board. Can you test these?
          • 386
            • Jul 2012
            • 30
            I just tested them all, and they all seem fine, both sides of the PCB.
              How did you test them? (Just to be sure.)
              • 386
                • Jul 2012
                • 30
                With a multimeter.
                  Originally posted by 386
                  With a multimeter.
                  On ohms range?
                  • 386
                    • Jul 2012
                    • 30
                    Yeah, none of them showed any signs of notable resistance.
                      You mean the resistance was very low? OK, that means they are good.
                      The problem is likely in the audio circuit as you get the 8 blinks indicating audio problem. It could indicate a problem elsewhere.
                      I'm trying to browse the service manual but having difficulty getting a downloaded copy (MediaFire's viewer is crap; and when downloading it complains of a suspended account?!) The detection circuit for 8 blinks is on page 29 but when I try and zoom in it just changes page. Using Firefox.
                      Could you send me a PM so I can send you my email address, then you can email me the manual. I can then upload it on http://www.tgohome.com/ServiceManuals/.
                      Looking at the ckt, it looks like it only does overvoltage detection for 13V; if the zener for the protect ckt is short, it will always signal an OVP event. (Hence 8 blinks.) But I can't clearly see if there are other protections or the part # on the zener to reference it with the board and a replacement.
                      Did problem occur suddenly, or slowly get worse?
                      • 386
                        • Jul 2012
                        • 30
                        I didn't upload the manual, and I too had some frustration using the mediafire viewer. I'll let you know if I manage to get the original PDF. It's possible to right click the pages and print them to PDF, but it means doing each page one by one.
                        I can take some closer photos of various sections of the board if it will help locate the diode(s)?
                        Unfortunately, I am unsure of how the problem developed, I received the TV in it's current state.
                        Thanks for all your help.
                          That's fine. I get a lot of TVs to repair without knowing what the previous problem is.
                          Can you "print to PDF" page 29 as PDF and upload it here?
                          • 386
                            • Jul 2012
                            • 30
                            Yeah sure, here it is:
                            Edit: Just realised I could upload to the forum directly.
                              Okay, it looks like all the protection does is sense over-voltage, DC voltage on the speakers, and watches for the FAULT signal from the amplifier IC. Page 37 has a board layout with part numbers on it. I can't seem to find this print to PDF option so can you upload this too.
                              It could be:
                              - Shorted amplifier driving speakers to DC
                              - FAULT signal from amplifier IC
                              - Over-voltage protect
                              - Failure of any of these detections
                              What you can try and do is locate R2204 (100k chip resistor), lift one leg of it, and see if TV powers up. Disconnect the speakers to prevent DC damage, if there is any. (You can check later with a meter to see if the speaker outputs have DC on them.)
                              If it then powers up, you can either replace the BG1 board (pricey option), or you can try and locate the fault. My bet would be either the OVP zener is short, or the amplifier chip is shorted to DC. (Possibly both were damaged by over-voltage, for example a surge...)
                              • 386
                                • Jul 2012
                                • 30
                                Pages 37 and 38:
                                • 386
                                  • Jul 2012
                                  • 30
                                  R2204 is on page 38, in the bottom right-hand corner. I'm not sure I'll be able to solder something that small though.
                                    I'm having no luck seeing R2204!
                                      Oh, I see it.
                                      Very tiny. It will be tricky but to remove an SMD component (it is probably too small to lift just one leg) blob a bit of solder over it. Then it will come off easy with the blob.
                                      If the TV then powers up, then the fault is being suppressed temporarily.
                                      You probably won't be able to easily reattach it, so you would need to order a reel of 100 or so of them, for about £1.
                                      • randtek
                                        • Oct 2011
                                        • 280
                                        • US
                                        Have you tried unplugging the speaker connector? I have seen problems like this caused by a piinched speaker wire.
                                        • brithepi2k
                                          Sony KD-65XE8596 no standby light
                                          by brithepi2k
                                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                          cheers...
                                          09-06-2025, 02:22 PM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
                                        • androripara
                                          Sony Bravia 55HX820 - 4 times blinking red standby led
                                          by androripara
                                          i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
                                          I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
                                          Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
                                          10-19-2023, 05:16 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • Elecfronicsssss
                                          DA0NJJMBAG0 charging light blinks
                                          by Elecfronicsssss
                                          Laptop motherboard DA0NJJMBAG0
                                          PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                          CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                          GUIDE ME WITH THE PROBLEM..
                                          SUMMARY-
                                          1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                          2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                          05-12-2025, 02:32 AM
