Sony kv27fs120.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    Sony kv27fs120.
    Sony kv27fs120 no startup stand by light displays 4 blinks.
  • RON_CET
    • Jun 2012
    • 217
    Re: Sony kv27fs120.
    check for 9 volts, open IC 603 9 volt reg. or if you have the 9 volts then look for
    defective horz.output transistor and ic001
    Ron Driver,BSEE,CET,ISCET,NESDA
    • dominik0801
      SONY KDL-43W755C | 5 blinks stand-by LED
      by dominik0801
      Hello guys.
      Today I got this TV for free, the friend included a "new" (used) TCON with it, since he told me, that doesn't work either.
      With the stock TCON, this TV turns on, stays on, but the screen only has 5 RED vertical lines on it, and that's it.
      Backlight stays on and is fine.
      With the "new" TCON, the TV turns on, shows SONY logo, some spinning circles, then the TV goes blank, and the stand-by LED is blinking 5 times, won't react to anything.
      I have read some forums, where it's been told that the part number is not always enough...
      12-18-2023, 11:40 AM
    • jason123
      Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
      by jason123
      Hi there,
      I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
      So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
      I see 2 posts that are relevant:
      https://www.badcaps.net/forum/troubl...j-oled-5-blink
      https://www.badcaps.net/forum/troubl...g-hardware-dev...
      10-29-2025, 02:01 PM
    • GoodCapDude
      Sony XBR-75X940E intermittent 6 blinks error code
      by GoodCapDude
      Hi everyone. First post on Badcaps!
      I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
      09-20-2025, 06:07 AM
    • AK_777
      Sony KD-65A1 Repair – 4 Red Blinks Error
      by AK_777
      Hi everyone!
      I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
      Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
      02-20-2025, 04:15 PM
    • jchon
      Sony A1e 5-blinks help
      by jchon
      Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
      I found the service manual, which was critical to know where to probe.
      https://www.manualslib.com/manual/20...1e-Series.html
      With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
      Unfortunately the 5-blinks...
      06-28-2023, 11:52 AM
