JVC lt-47x579 backlight comes on but nothing else
    Re: JVC lt-47x579 backlight comes on but nothing else
    If you remove it, the set should power on normally with a good picture.
    I couldn't find the exact part in quantities any less than 3,000. You might have to see if the TV does get upset without it. Maybe different voltages are or eBay could be a source.
    • JC1979
      • Jul 2012
      • 17
      • canada
      Ok, thanks. I will remove it and see how it goes.
      • JC1979
        • Jul 2012
        • 17
        • canada
        Ok, so i took the board into an electronics shop that i have dealt with before, i had them remove ic2502. came home put the board back in, plugged everything in. hit power and nothing. I have the blue standby light on, but if i hit power on the tv or remote it does nothing. Any suggestions?
        • RON_CET
          • 217
          So your saying now you don't even get the backlight glow you had before?If so and your sure you have all connectors properly seated,then possible the design of the micro on that board if it don't see any type of voltage reset will not allow unit to boot up,which means your going to have to install that IC you removed with the part number from post#15
          Ron Driver,BSEE,CET,ISCET,NESDA
          • JC1979
            • Jul 2012
            • 17
            • canada
            Ok, ive looked and cant find it in quantities less than 3000. anyone out there know where i may be able to get one of these. Im willing to even change the whole board if need be at tnis point, but i cant seem to find one of those in stck anywhere either. Anyone out there have any sources tnat may be able to find either the part or the whole board.
              I've done some cross-referencing and found this part to be an equivalent substitute:
              Farnell have it at £0.33 in single quantities, and in the 2.7V range, which is *probably* close enough.
              http://uk.farnell.com/jsp/search/bro...D2031%2B203653
              I just noticed it's out of stock but if you give them a ring they will get you a lead time and might even have a few left in stock.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Do you think that he could go with a 3v one? Mouser has a 2.7v one but its on-order, they do have a 3v one in stock though.
                Edit: nevermind, thats still too close to 3.1v. Mouser does have a 2.5v one though!
                Muh-soggy-knee
                  I think the 3V one is what caused the problem in the first place but it may work...
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Mouser has a 2.5v one.
                    Muh-soggy-knee
                    • ITH
                      • Sep 2012
                      • 4
                      • mexico
                      #30
                      hello, does it works?
                      i have the same issue and wanted to now if replacing IC 2502 is the solution
                      thanks in advance
                      • JC1979
                        • Jul 2012
                        • 17
                        • canada
                        #31
                        I will be honest. I never did order the part. The tv was in the spare room. Out of sigt out of mind. Well thanks to this reminder i just ordered the part and paid feo the expidited shipping so it should be here in a day or two. After i get it back together i will definitely post and let you know if it works.
                        • JC1979
                          • Jul 2012
                          • 17
                          • canada
                          #32
                          Ok. So the part came in today. Took it to guybi was going to get to solder it and first question he had was which way does it go? I showed him the picture posted by RON_CET here https://www.badcaps.net/forum/showpo...8&postcount=17 and it still leaves me two ways of putting it on. In the picture it shows one of the little prongs blacked out. any help would be apreciated. Thanks.
                            There will be one slightly thicker lead on that device that lines up with the black pin.
                            • JC1979
                              • Jul 2012
                              • 17
                              • canada
                              #34
                              Perfect. Thanks tom. Will get her all put back tomorrow and will let you know how it goes.
                              • Ionized
                                • Nov 2013
                                Has this ever been resolved? I have the same model doing the same thing. The VReg readings I get are 2.48 VDC & 3.25 VDC (legs 1 & 3). Is there a test for IC 2502?
                                • JC1979
                                  • Jul 2012
                                  • 17
                                  • canada
                                  #36
                                  No. Never got it working. Had it soldered on. Didnt work so the set is now sitting behind a dresser In my spare bedroom. If you ever figure it out let me know.
                                  • triplefour
                                    by triplefour
                                    09-13-2023, 10:43 PM
                                  • DanPoka
                                    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                    by DanPoka
                                    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                    02-15-2025, 05:05 AM
                                  • Comp_Pro
                                    No Backlight Macbook A1990 820-01041
                                    by Comp_Pro
                                    Hello all,
                                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                    Tests performed:
                                    There is no backlight even with a good screen.
                                    Backlight IC is receiving the correct support voltages.
                                    Fuse F8400 ok
                                    Current sense resistor R8400 ok
                                    Backlight IC is receiving 3.3V on enable pin.
                                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                    Backlight IC receiving 5V from PP5V_G3S
                                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                    05-06-2024, 10:23 PM
                                  • cheebster
                                    iPad Pro 12.9 5th Gen Backlight Issue
                                    by cheebster
                                    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                    Anyone...
                                    05-20-2025, 09:17 AM
                                  • canadaboy25
                                    LG Flatron 24EN33TA No Backlight When Cold
                                    by canadaboy25
                                    I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                    I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                    03-07-2023, 12:23 AM
