Samsung LNT4069FX/XAA no picture with sound
    Re: Samsung LNT4069FX/XAA no picture with sound
    Does the power LED ever stop blinking? Sounds like main board.
    • stinger381
      • Apr 2013
      • 42
      WooooWhoooo ...... Mine is fixed .... Just like Ceconomon said, it was the Logic Control or AKA the FRC Board (Frame Rate Controller). Here is the deal that I later found out too. The model TV we have was one of the first generation 120 mhz LCD television and those LCD's had a seperate FRC Board and Main Board. They have since combined these two boards into the main board. Ceconomon solved my issue when he said he replaced the FRC Board as I had already replaced the main board, the T-Conn and the power supply. I had no idea that the FRC board is usually part of the Main Board and that mine were seperate. Thanks again for the help and my TV starts up like a brand new one now.
      Tomm66, my LED Power light continued to blink red after I put the new power supply in it. Now that I have replaced the Logic Board it burns a solid red I think while the tv is operating. The logic Board is the small board above the main board and under the metal frame piece. It only has three wires attached to it and two go to the T-Conn and one goes to the Main Board.
        Most newer Samsung TVs have the FRC on the T-con. I always disable the effect, the picture never looks right with it on.
        • salongaopm
          • Mar 2013
          • 13
          • usa
          #64
          no. keeps on blinking. main board was replaced already. no change.
            Look above at FRC board then, seems it may be a common fault.
            • salongaopm
              • Mar 2013
              • 13
              • usa
              #66
              I also replaced the Logic Control or AKA the FRC Board (Frame Rate Controller) but no change.
              • stinger381
                • Apr 2013
                • 42
                Well those are pretty much the only parts in the tv that are replaceable. Main board, power supply, t-conn, and logic board. If you are still getting the white screen and sound I would bet you have a bad logic board still. Otherwise, I have no clue and would suspect a bad LCD panel.
                • salongaopm
                  • Mar 2013
                  • 13
                  • usa
                  #68
                  now, i am suspecting that one the board i purchased might be a bad one. the logic board and power supply are new as claimed by the seller. i need to figure out a way to test which one is defective without spending to much. sigh.. ):
                  • salongaopm
                    • Mar 2013
                    • 13
                    • usa
                    #69
                    found the problem. the main board that i purchased is defective. original tcon, power supply and main board are all working properly. only the logic board is defective. finally i got it to work. thanks guys!
                    • stinger381
                      • Apr 2013
                      • 42
                      So it was the logic board .... glad to hear that you got it fixed and working ! I am enjoying having mine back too. Thanks again Ceconomon.
                      • georgerallen_1@msn.com
                        • Jun 2014
                        I replaced FRC board to get mine working. However, when I measured the voltage on pin 4 of IC107 the voltage still measured about 1.79 volts. I am assuming this is about normal and the biasing of IC107 is different than that of IC102. The television appears to be working fine after replacing that board.
                        • veikra
                          • Sep 2012
                          • 55
                          • canada
                          #72
                          I want to confirm that 1.8V on pin 4 is correct and with accordance to the datasheet . Same tv with white screen issue. Looks like tcon or FRC board , still digging.
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • Mgiffune
                            by Mgiffune
                            I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                            I ordered a supposedly β€˜new' Tcon board this time, and
                            06-09-2024, 10:28 AM
                          • Ierwin
                            by Ierwin
                            05-13-2025, 03:31 PM
                          • jchang
                            Samsung UN70NU6900F no picture and no sound
                            by jchang
                            Hi all
                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                            Symptom:
                            No picture no sound.
                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                            No sound at all.
                            What I tried:
                            1. I tried unplugging the left or right ribbon...
                            01-09-2023, 06:28 PM
                          • marekk
                            Samsung QE55Q67RAT no sound and bad picture when streaming
                            by marekk
                            I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
                            I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
                            Mainboard is based on pcb BN41-02695A BN94-14007B
                            I will appreciate any help
                            Many thanks
                            Marek...
                            05-29-2025, 02:23 AM
