Help- Vizio VW42L HDTV10A
  • Amuyamula
    replied
    Re: Help- Vizio VW42L HDTV10A
    Success!
    I also found an offending bulged capacitor under the power supply heat sink (470uf 25v).
    The tv powers up and works great! I attached a picture for your reference.
    Thanks all!
    replied
    If you are not sure how to solder surface mounted device, just take it to the local shop and give them the new part to install instead.
  • Amuyamula
    replied
    OK, then I will replace U33 since that isn't outputting 3.3v.
  • retiredcaps
    replied
    Originally posted by Amuyamula
    Your #40 post indicates that maybe U9 is bad. Thanks for all your help!!!!
    Nope. Your U9 is good. You report pin 2 is 1.5V for U9. The part number tells us that the expected output voltage is 1.5. So your U9 is good.
  • Amuyamula
    replied
  • retiredcaps
    replied
    Being a newbie at this, I can only doubt its bad so Im going to swap it out.
    Start with post #31 and re-read everything until your first post.
  • Amuyamula
    replied
  • retiredcaps
    replied
    Amc1117
    FD7416
    and
    K1117S15
    736
    http://www.digikey.com/product-detai...98-1-ND/705738
    http://www.digikey.com/product-detai...ICT-ND/1301519
    Now my question to you is:
    Do you think U9 is still bad?
  • Amuyamula
    replied
    Amc1117
    FD7416
    and
    K1117S15
    736
  • retiredcaps
    replied
    Know any Digi-Key part numbers for these 4 regulators?
    Provide the actual part numbers of your regulators. The part numbers in your pics are not readable.
  • retiredcaps
    replied
    Originally posted by tibimakai
    U33 it's bad. Should be 3.3V(where do you have 4V) and it's supplying the U7 and U9 with higher voltage.
    This is exactly why I always ask for actual readings.
  • Amuyamula
    replied
  • tibimakai
    replied
  • Amuyamula
    replied
    Plugged it in, hit the power button and took the following voltage readings:
    U9
    Pin1=0
    Pin2=1.5 volts
    Pin3=4 volts
    U7
    Pin1=.03 volts
    Pin2=1.27 volts
    Pin3=4.03 volts
    U33
    Pin1=2.79 volts
    Pin2=4.03 volts
    Pin3=5.10 volts
    U8
    Pin1=2.04 volts
    Pin2=3.28 volts
    Pin3=5.15 volts
    Here's a picture.....
    Thank you!
  • Amuyamula
    replied
    I will post a pic and get readings as soon as I get back home from a trip. Thanks! You guys are so helpful!!!!
  • retiredcaps
    replied
    I have a bad U9 on my main board
    Can anyone provide Digikey part number for K1117S15 that is on the main board?
    1) Post a picture of your U9 so we know what package it is. Follow my sig file exactly for posting a picture.
    2) What are your readings for U9?
    3) In digikey, click on "in stock" and type in "1117 1.5v regulator" into the search field. Once you have correct package type selected, your choices will narrow down significantly.
  • Amuyamula
    replied
    Hi all!
    Thanks!
  • retiredcaps
    replied
    Selldoor also helped someone figure out that U2 was bad
    https://www.badcaps.net/forum/showthread.php?t=20801
  • XmouseX
    replied
    Thank you so much for your help. I will make sure that I check the surrounding capacitors as you suggested and order a new regulator. Thank you for responding back so quickly on my posts
  • retiredcaps
    replied
    Originally posted by XmouseX
    So this means U9 is bad?
    Look at your readings in post 33. You measured pin 2 at 1.51V. As PlainBill would have done if he wasn't MIA, he would ask you is this good or bad now that you know how to interpret the part number?
    Hint: Reread posts #34 and #40 again slowly.
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
  • mrtek
    Vizio M65-C1
    by mrtek
    Hi.
    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
    07-14-2025, 07:28 PM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
  • howardc64
    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
    by howardc64
    Failure Symptom
    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
    Where is the short?
    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
    05-27-2025, 02:56 PM
