LN40B550K1FXZA - block of colored lines
  • jeremysaffir
    • May 2012
    • 15
    I bought the TV like this, pretty cheap. This is what the guy I bought it from has tried so far:
    The T-Con Board has been replaced, as well as the main board, and the issue persists. He also replaced a bunch of capacitors on the power board, just as a shot in the dark.
    I haven't tried much with it, yet, and I'd like to get a few ideas going before I tackle it.
    From what I understand, it's highly likely that the LCD panel is bad. If so, no big deal, I'll buy a replacement and be done with it. However, I think the black block there indicates maybe it's not a display problem. I guess the first thing I'll try is reseating every ribbon cable in there.
    However, I'd like to be sure before I buy what is probably the most expensive part.
    So what do you guys think?
    P.S. the cheapest replacement I've seen for this LCD panel is http://www.partstore.com/Part/Samsun...furbished.aspx
    I checked shopjimmy.com and didn't see it there at all. Any other places I might want to check?
  • Mr Bill
    • Nov 2011
    • 648
    Re: LN40B550K1FXZA - block of colored lines
    Looks like a bad panel. Here is a picture of a sony bravia kdl that had a bad panel. Does twisting or flexing the panel make any difference. You might find better search results if you pull the back off the tv and get the panel make/model off the sticker.
    • jeremysaffir
      • May 2012
      • 15
      Hmm. That Sony sure looks exactly the same. I tried twisting/flexing, but it's pretty tough to do without taking the back off the TV. In any case, no amount of tapping, pushing, squeezing, twisting or flexing (again, TV in one piece) has affected the issue one bit. Tomorrow's the weekend, I should have plenty of time to take the back off and mess around a little more.
        It does look like bad tab bonding problem.
        • jeremysaffir
          • May 2012
          • 15
          What's a bad tab bonding problem mean? Probably not repairable, in any case.
          • Mr Bill
            • Nov 2011
            • 648
            unfortunately the only "repair" that could be done is applying pressure on the tab bonds to see if the image comes back. But as you stated last night that twisting or flexing makes no difference then you might be "peeing in the wind"
            The sony picture i posted couldn't be fixed by applying pressure to the tab bonds so i had to strip the tv and part it out.
              More likely with random lines or no image at all, it is a complete failure of the driver IC on the tab bond.
              • jeremysaffir
                • May 2012
                • 15
                I took the back off. Tried twisting the whole panel, pressing along the top, reseated and tried fussing with the connectors. No change, really. A small portion of the colored lines went kind of fuzzy or whatever, though I'm not really sure why -- seemed to be regardless of all my messing around.
                So, seems likely to be a bad LCD.
                Any other ideas or is it pretty certain to you guys too?
                Just want to be sure before I shell out $160 on a new LCD panel. -- which, I'd like your opinion on, too. Is it worth spending $160 on a new LCD panel for this TV? Is there a better deal out there?
                  You can probably strip the TV for parts. Look on your local craigslist, you can get faulty TVs for parts. Maybe you'll find a faulty Samsung (very common) with similar parts (also common.)
                  • jeremysaffir
                    • May 2012
                    • 15
                    Well, my first question is how much would I really get for the parts? (and how long would it take to sell all the parts?)
                    I bought this TV for cheap hoping to fix it cheap just so we could have a decent TV without buying a brand new one, so I prefer to fix it, if it's still worth it.
                    I would be OK with stripping it and just trying again, but unless you tell me the TV isn't worth enough with a new LCD panel, I'll just get the new LCD panel.
                    So my question is... in your opinion is it worth the price of a refurbed/harvest/used LCD panel at $160?
                      Can't really say how long, maybe a couple of months. The PSU, main board and T-con are all common failures and are worth at least $30 each.
                      I've done the same thing. I got a 42" for £20 and fixed it for £5 so I kept it for the living room.
                      I'm not certain it is worth $160. For one, you can't be certain of the condition of the harvested panel. Fingerprints, scratches, marks etc... But it should work okay with the panel replaced.
                      • jeremysaffir
                        • May 2012
                        • 15
                        Well thanks for the input, I appreciate it. I guess I just have a decision to make.
                          09-07-2024, 05:50 AM
                        • Falki
                          Colorful LCD Vertical Lines on Samsung ue55es8090
                          by Falki
                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                          A similar issue has been posted as well but also with no actual response ...
                          08-12-2025, 04:19 AM
                        • Rubenlily
                          Samsung QE50Q67TAU - horizontal lines
                          by Rubenlily
                          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                          I'm no expert but I've done the tape...
                          08-16-2023, 01:12 PM
                        • jeyoung12
                          Samsung QN50Q60t lines on screen
                          by jeyoung12
                          Hi all
                          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                          So....i don't know what end of the C ribbon to work with...
                          02-26-2024, 10:38 AM
                          09-06-2024, 11:40 PM
