Insignia/Polaroid NS-LCD42HD Tcon LVDS cable
  • electronicsurplus
    • 210
    Hello all,
    I have a Insignia/Polaroid NS-LCD42HD and broke the LVDS cable when removing, wires fell out I need to replace but do not know the pinout
    Does anyone know what the connection pinout on the Tcon side is?
    I have searched high and low for this cable and cannot find it
    Thank you very much
    This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
    Help keep these from the landfills
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
  • netgearnetgear
    TCL 43S423 TCON OR PANEL FAULTY???
    by netgearnetgear
    Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
    08-20-2025, 06:04 PM
  • Daren87
    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
    by Daren87
    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
    08-13-2023, 03:25 PM
  • MikeRWK
    Insignia Roku ns-50dr620ca18 (NS-50DR620NA18) bad panel or tcon ic?
    by MikeRWK
    Picked up this roku tv yesterday. Its got colored vertical lines on both sides of the screen, some flickering vertical lines, and image stabilization issues. The guy said his kid threw a controller at it, but the screen doesn't seem physically damaged.
    When I unplug the cable going from the main board to the tcon the screen is all black for what its worth.What I want to know is if the screen is damaged or the tcon? All the voltages on the tcon checked out but that doesn't mean the tcon ic isnt damaged.
    Here's a video
    https://streamable.com/ab0j59
    01-10-2021, 10:00 PM
