Insignia/Polaroid NS-LCD42HD Tcon LVDS cable
  • electronicsurplus
    • Jun 2012
    • 210
    Hello all,
    I have a Insignia/Polaroid NS-LCD42HD and broke the LVDS cable when removing, wires fell out I need to replace but do not know the pinout
    Does anyone know what the connection pinout on the Tcon side is?
    I have searched high and low for this cable and cannot find it
    Thank you very much
    This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
    Help keep these from the landfills
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
  • netgearnetgear
    TCL 43S423 TCON OR PANEL FAULTY???
    by netgearnetgear
    Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
    08-20-2025, 06:04 PM
  • Daren87
    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
    by Daren87
    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
    08-13-2023, 03:25 PM
