Insignia 37 inch LCD, has sound, but no video. What to do?
  • Umortal377
    • Jun 2012
    • 7
    Got a 37 inch Insiginia, model NS-LCD37. Wife called me the other day and said the tv wasn't working. After checking it out, it seemed the sound was working, but no video. The TV comes on normal looking for a second or 2, then kicks out to darkness.
    I did notice however in a completely dark room, I can make out outlines or very faint images on the screen.
    I opened it up and took pictures to post, but realized I didn't bring the cable with me to hook it up, so I cannot post any pics till tomorrow.
    I didn't see anything that stood out as bad. However, I didn't take everything off. But did look around some.
    My soldering skills are ok, not the greatest. But I have replaced a couple transistors and chips on some crane machines and arcade games I use to collect. So I know enough to probably hurt myself, lol
  • smalltownguy
    • 127
    • US
    Re: Insignia 37 inch LCD, has sound, but no video. What to do?
    The famous "2 seconds to black" behavior. You have a fault in the backlight circuit. Either a bad inverter board or bad CCFL tubes. More likely the inverter.
    Bad capacitors in the inverter circuit will cause this. We've already established that you don't have the capability to test any of the caps, so shotgunning the inverter board is probably your best bet.
    Get some good quality pictures up so we can see what you've got and we'll go from there.
    -STG
    • Umortal377
      • Jun 2012
      • 7
      Thanks, I will try and get my pics on here tomorrow morning. Think I found some replacement boards online, but want to check the TV to make sure the parts are the same.
      I still wouldnt mind trying to fix this board. I have a soldering gun and a multimeter. But we recently moved, so I have no clue where they are at. Gonna look for them tonight.
        Yes, do post the pictures and do some voltages checking first before start buying boards. You may want to read this also.
        • retiredcaps
          • Apr 2010
          • 9271
          The shotgun approach is contrary to philosophy and skills of most of the regular members here.
          --- begin sig file ---
          --- end sig file ---
          • Umortal377
            • Jun 2012
            • 7
            I tried to load the pics this morning, but I got an error saying:
            Your submission could not be processed because a security token was missing
            • Umortal377
              • Jun 2012
              • 7
              Looking at all the boards I could see, I dont see any damage.
              I did pull the inverter board all the way out. Looking online, I couldnt find an exact match on the part #. The part # is VK8A183I0207. Looking online, I can find something close, but not exact. I found a VK8A183I07.
              • Umortal377
                • Jun 2012
                • 7
                I still plan on trying to fix the board. But I want to get the TV up and running, then tinker with working on the old board in my spare time. Still havent found my multimeter or soldering setup.
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  Hi - nothing to do with a security token - your pics are just too big they need to be under 2mb 2000x2000 - you will need to downsize them a bit.
                  • Umortal377
                    • Jun 2012
                    • 7
                    Here are some pics
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      I would test the secondary windings on each inverter transformer
                      No power to the board meter on 2000 ohms when you find it check
                      as per pic S1>S2 and S3> S4 No need to remove to check.
                      Post results as follows
                      T1 S1>S2 = xxx ohms S3>S4 = xxx ohms
                      T2 S1>S2 = xxx ohms and so on.
                      SORRY - Set meter on 20,000 ohms these should be just over 2000
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        Actually I cant make out all the part numbers on the transformers but they dont all look the same which is a bit odd perhaps you can list them I thought I saw 6007 and 6004
                        Its the first 5 digits that are important.
                          F1, F2, F3 are good? This board looks like one of those DARFON with bad transformers.
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            Originally posted by budm
                            F1, F2, F3 are good? .
                            Old Yesterday, 06:51 AM #1
                            Umortal377
                            I think that covers most fuses?
                              If one of the fuse on the inverter is open, you will see backlights on and then goes into shutdown since the PWM IC of the inverter will detect that not all the lamps fire up. It is also why when you have open winding on the secondary side of the inverter transfomer, the inverter will go into shutdown due to lamp did not fire up, the widows on most circuits is about 1.5 second of detection time, anything does not happen after 1.5 seconds, it goes into shutdown during the lamp fire up and stays conducts sequence. Hence you are seeing these 2 seconds shutdown.
                              Just to be sure.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Yup, there is a documented case study that I highlighted in my 2 seconds troubleshooting guide the above scenario.
                                https://www.badcaps.net/forum/showthread.php?p=197027
                                • Umortal377
                                  • Jun 2012
                                  • 7
                                  Just a followup, after replacing the inverter board, the TV now works.
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    The good transformers off the old one will be saleable as I recall they are about 20$ each so probably worth the effort removing and testing.
                                    • Daddyfixit
                                      • Jun 2013
                                      • 20
                                      Hi all I have to thank you all for sharing what you do, but I'm having a problem with my Insignia NS-LCD37 also. Having said this, everyone talks about the red light on then going to green, but mine goes to blue, and I see nothing but black? I have read as much as I could about similar models but, I'm not sure where I stand in comparison to others with similar models.
                                      The TV worked great for over five years but now no longer powers up, I only have that red light stating that I'm plugged in and when I hit the power I don't see anything but the blue light on and no sound. I have it apart but I definitely don't know where any main fuses are or know exactly how to check the transformers. All my caps look super clean and I went as far as I could testing my main ac board. The values didn't all match so I condemned that board, ordered it, installed it and no luck. Transformers are what I'm assuming but the ohm test you've posted to test doesn't match what I read, but still not sure as to which direction I need to go in my case. Any help will keep my daughter and wife's faith in the daddy can fix it phrase alive . Please advise
                                        Please go back to this thread or stick to this one so we do not have to try to follow 2 threads, thanks.
                                        https://www.badcaps.net/forum/showth...110#post349110
                                        • soeren
                                          A2442 - No sound over internal speakers and no video playback
                                          by soeren
                                          I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                                          All happened after the battery ran out of power overall several days when I was on vacation.
                                          I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                                          07-26-2024, 01:24 AM
                                        • FrancescoV
                                          Onkyo HT-R390 no sound output, video output ok
                                          by FrancescoV
                                          Good morning everyone,
                                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                          The firmware reported is the following:
                                          M:1.00/11107BLP
                                          D:?.??/????????
                                          O:1.00/11107AL
                                          The DSP firmware given the question marks seems corrupt.
                                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                          05-11-2025, 02:59 AM
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                        • Max514
                                          Samsung UN55H8000 sound but no backlight no video
                                          by Max514
                                          Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                          The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                          I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                          • Unplugging the main board cable at the power supply >>> backlights came on.
                                          • BLU_ON signal from the
                                          04-14-2022, 10:34 AM
                                          HP ZBook Firefly 16 inch G10 Notebook Specification for Upgrade or Repair
                                          This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 07:20 AM
