VISIO Model VP50 HDTV 20A (screen dead)
  • robertcolombo
    • Feb 2012
    • 5
    • usa
    I know something like this has been covered time to time, BUT!
    Can anyone shed some more on this for me.
    I have no inputs going into the TV, just power.
    This is what happens.
    Plug in and push power button, the power light on front goes from amber to green and stays on.
    The screen does not light, Black, Black (Dead).
    I removed the back, this is what I see, all capacitors look new.
    Checked all ceramic fuses with VOM , all are good.
    When I plug in the power cord, relays on the lower right power board (double click).
    When I push the power button, again relays on the power board (double click) followed by the
    logic boards LED lights 2000, 2001 and 2003 lit up, a second later logic board LED 2002 lit up
    for a second and then all the logic board LED's go off and the speakers pop, followed by
    LED #1 on the power board starts to blink continuously.
    I have tried unplugging X and Y boards from the power supply, one at a time then all with the same above results.
    Guy's any help on this would be appreciated.
    Re: VISIO Model VP50 HDTV 20A (screen dead)
    Can you post a picture of your power supply and other boards? I suspect this is an AC detect failure or a sudden power supply shutdown due to the speaker pop noise.
    • robertcolombo
      • Feb 2012
      • 5
      • usa
      Hope you can view video.
      http://www.use.com/75238ab6e5ea01448820
      Thanks,
      • Mr Bill
        • Nov 2011
        • 648
        What is the panel Model? Looks exactly like my 50" philips in my basement that has a samsung S50HW pdp panel
        • robertcolombo
          • Feb 2012
          • 5
          • usa
          • Mr Bill
            • Nov 2011
            • 648
            There will be a sticker on the back of the plasma panel. Here is a pic of my 50" philips
            • robertcolombo
              • Feb 2012
              • 5
              • usa
              OK, here are the labels on the back and inside the unit.
              http://www.use.com/a4fa12d6d9c7501304bf
              • Mr Bill
                • Nov 2011
                • 648
                I upload the wrong picuture , guess the old age bug is starting to bite. The sticker is actually on the back of the plasma panel inside the tv. It may be somewhere in the upper left or right corner. How long does the tv run before the speakers give a pop noise? Have you attempted to check voltages? Is there a table on the power supply showing what led #1 would be. It seems the power supply is going into protection mode.
                • robertcolombo
                  • Feb 2012
                  • 5
                  • usa
                  There are two photos that I sent , one is the one your talking about.
                  The speakers make a slight pop like the audio amp is going on and the when the logic board LEDs go off the slight pop goes off again like the power amp is going off. I think that's all it's doing, the audio amp going on and off.
                  The screen never comes on at any time. I can't get to checking the voltage, the power amp is turning off to fast.
                  • CoppellTVRepair
                    • 39
                    There are two different and popular reasons for problems in VP50HDTV20A:
                    One is the Y-Main sustain/buffer boards issue and that's the more popular one.
                    You can read more about it at our blog and here's a listing to a diagnostic/repair service:
                    http://www.coppelltvrepair.com/p/805...n-board-repair
                    This is the most common and also most costly repair this TV can have; in some cases it may not be worth doing it at all - it really depends on what caused the failure in the first place.
                    The second is a failed power supply board.
                    This is less common compared to the above however it also fails in several different ways.
                    There's a video on YouTube by a guy proudly showing two bulged capacitors in the power supply.
                    If you can see bulged caps go ahead and replace them - ideally yourself, but if soldering to you is what car mechanics are to me then you'd better have someone else do it. Someone local would be preferred as this is an easy task and it is not worth the shipping costs, let alone risls of breaking.
                    But if you have a blown fuse or no signs of failure at all then it may be more complicated and you may want to send it for repair to someone who has done it before.
                    Here's a link for that too:
                    http://www.coppelltvrepair.com/p/832...-on-and-off-tv
                    Replacing a blown fuse hardly ever helps repair a power supply. There may be exceptions, but most of the time the fuse is the last thing to fail in a chain of failures and replacing it and trying the board again just gives a few other components a chance to fail.
                    Hope this helps!
                    • Tech 57
                      • Aug 2014
                      • 37
                      I have the same problem
                      Did anyone figure it out.
                      Also i pulled the main reading shorts all over the HDMI ic
                      Maybe this is the problem u22
                      Thanks phil
                      • Rav_tangle
                        MacBook Pro 2011 turns on with keyboard light , screen dead
                        by Rav_tangle
                        Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                        I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                        Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                        is this...
                        05-31-2024, 04:09 PM
                      • NeilMcG
                        Hp Elitebook - Dead Screen
                        by NeilMcG
                        Hello all,
                        First time posting, so please be gentle 😂
                        HP Elitebook 850 G2 Win 10 with Intel HD Graphics 5500.
                        Screen dead, but booting.
                        I connected it to an external monitor via both VGA & Display Port outputs and external monitor works fine, nothing with F4 or detecting another screen in settings.
                        Got a replacement panel, still dead & still displayed to external screen as before.
                        Removed CMOS & left it. CMOS reconnected, all as before, no panel, external monitor works.
                        Got replacement cable...
                        12-06-2024, 03:23 AM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
                      • Donny2derby
                        LGOLED55B7V Clicking and dead screen.
                        by Donny2derby
                        Picked this up other week and when I originally looked at in the sellers house I got 3/4's of a working screen and some horizontal lines across the 1/4 of it which was dead/black.
                        Just tried powering it up at home and now all I'm getting is a clicking and some very faint lines on 1/4 of the screen whilst the entirety of it is dead.
                        When using the remote I get two red clicks on the standby. Not sure if this means anything or helps. The same when I use the manual power up.
                        Help appreciated. I'm an electrician, I've fixed a few in the past so not a total...
                        08-10-2023, 04:23 AM
