Memorex MLT4221P stuck in standby
  • retiredcaps
    • Apr 2010
    • 9271
    #61
    Re: Memorex MLT4221P stuck in standby
    Put the original caps back in so it fits.
    Odd, that the 18V rail is working fine at 12V. What a waste of time chasing down that rail.
    --- begin sig file ---
    --- end sig file ---
    • gb77
      curious
      • Aug 2011
      • 76
      #62
      yep - nice of them to confuse anyone without the service manual by marking the pcb 18v. i put the old caps back in & tested the p/s and it worked fine. since the mb died & i found out the tv is used as an all day security multi-cam monitor, the old p/s prolly is likely not gonna last that much longer in the heat either.
      • lepak06
        TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
        by lepak06
        Hello
        I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
        The TV is faulty with stuck in Standby RED LED. Can't power the TV.
        Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
        All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
        But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
        01-12-2023, 01:43 AM
      • toty79
        Hisense LTDN50K220WSEU stuck in standby
        by toty79
        Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
        As per Hisense tv title LTDN50K220WSEU stuck in standby
        PSU rsag.820.5687 HLL 4855WF
        Main rsag 7.820.5842
        I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
        05-01-2022, 04:39 PM
      • lego1234567
        LG 32LB1R - stuck in standby mode
        by lego1234567
        Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
        What could be the problem ? Thanks...
        01-21-2024, 03:39 AM
      • Rusenga
        Samsung UA39EH5003R Stuck on standby
        by Rusenga
        Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
        Connector CNM803:
        TV ON
        Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
        TV OFF
        Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
        09-18-2021, 11:51 AM
      • Ukdigger
        Samsung UE46f5000AK Stuck on Standby
        by Ukdigger
        When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
        PSU number bn44-00610A L46SF_dpn
        1 B13v 12.4
        3 B13v 12.4
        5 Vamp 12.4
        7 Vamp 12.4
        9 GND...
        08-08-2024, 09:17 AM
