TV on ebay: Panasonic th-42pz80a
  • psmedley
    • Apr 2012
    • 144
    Hi guys,
    There is a Panasonic th42pz80a 42" tv on ebay, about 10 minutes up the road from where I live - starting price is $A20.
    Description of the fault is:
    "originally there was a black line going down the side of the TV while it was on, shortly after it wouldnt turn on (details below)
    As soon as i press the on button, it makes 2 quick 'clicks' followed by another shortly after, the green light flashes for about five seconds and then turns red."
    Not sure about the black line - the not turning on sounds potentially cap related.
    Any thoughts before I go ahead and bid? The TV is full HD - so well worth repairing
    Re: TV on ebay: Panasonic th-42pz80a
    Black line is panel failure - unrepairable - common with Panasonics of this generation. http://www.youtube.com/watch?v=FXy2jHNpv_0
    No Panasonic that I know of has bad cap issues, they are extremely solidly built in that department (Rubycon, Panasonic, Chemicon and Nichicon caps throughout - nowadays they are moving more exclusively to entirely Panasonic and Rubycon), probably MC201/301 issue or another controller IC issue.
    • psmedley
      • Apr 2012
      • 144
      Thanks Tom - you just saved me some $$$
        I've repaired the TH-42PZ80BA which had a Y-sustain energy recovery problem - just a shorted MOSFET and lower buffer fault, nothing too difficult. As far as I know, the only difference is BA is the European model with SCART and DVB-T (free to air) and such. It is a very, very well built TV and gives a fantastic picture and brilliant sound - probably the best I've ever seen and heard from any LCD or plasma. But it is one hell of a beast... draws about 400W and weighs 35kg!
        • psmedley
          • Apr 2012
          • 144
          Have asked the seller if the black line is isolated to 1/6 of the screen which may indicate a buffer board problem as opposed to the panel...
            It's virtually always panel - Panasonic literature says replace the panel with ANY line from top to bottom. Left to right is almost unheard of but would be Y buffer or control board, or possibly even a loose Y buffer connector.
            • psmedley
              • Apr 2012
              • 144
              OK - I'll give it a miss then, shame.... I am hoping to snaffle 2x Viewsonic VX2835WM's on ebay today for a good price - these have the same power supply as the Hanns 28" so should be pretty easy to repair..
              If I won a 42" TV as well I think the wife would kill me :P
                Nice. I want another 24" LCD to repair for epic dual desktop-ness. Although the current 24" looks to be a squeeze... I dunno if I'll fit a second one on!
                • psmedley
                  • Apr 2012
                  • 144
                  Grrr the 2x viewsonics went for more than I wanted to pay need to look/find another project now :P
                  • psmedley
                    • Apr 2012
                    • 144
                    More on the Panasonic:
                    "the line was all the way down the screen, 3 cm wide, it was 9cm in from the right hand side of the TV, and the LED goes green for 2-3 seconds, followed by 10 flashes of red, it has 7 seconds then flashes 10 red times again"
                    line down the full length of the screen is a panel fault like tom suggests (as far as I can tell), so I'll definitely skip this TV and wait for something better to show up
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                      11-20-2024, 08:52 PM
                    • cubytus
                      Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                      by cubytus
                      Hi to all,
                      I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                      I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                      Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                      01-10-2024, 01:26 AM
                    • TrueSword88
                      Kogan - KALED65XU9220STB - Blue Vertical Line
                      by TrueSword88
                      Hi all.
                      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                      The line just happens to coincide with the end of COF and start of the next COF (attached).
                      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                      Hoping to fix...
                      05-05-2023, 04:28 PM
                    • AquaMan Ua
                      by AquaMan Ua
                      05-17-2025, 09:40 AM
                    • FALKLAN
                      Running Line Voltage and Integrating LED Pods - Automotive
                      by FALKLAN
                      Howdy everyone! I hope all is well where ever you are!
                      I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                      I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                      02-05-2025, 12:30 AM
