Vizio E321VL
Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most." -
Re: Vizio E321VL
Here is the T-CON board for E321VL:
http://www.shopjimmy.com/lg-philips-...-con-board.htm
PS: When you mark up a picture (redline) what program do you use?Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."Comment
Re: Vizio E321VL
Ah, Your chassis of the same model but does not have the same gut, so your chassis does not have seperate T-CON board. That so typical of who will provide the TV at the lowest price, so same model can have more than one chassis.
I create the PDF from ACROBAT 6 PRO, then I redline/marking it and then I save as jpg file.Never stop learning
Re: Vizio E321VL
What? I've heard of unreplaceable T-cons in 19" and 22" monitors.. but in a 32" TV? You've got to be kidding me.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Re: Vizio E321VL
They are trying to save as money as they can, and at the same time they make sure you cannot easily fix it.Never stop learning
Re: Vizio E321VL
I know of a new trick LCD manufacturers are doing. They're making their CCFL-based panels very thick so if you want a thin TV it must be LED-based.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: Vizio E321VL
So I will focus on the firmware and try to access it by using the side control buttons.You need to confirm you have the correct firmwareComment
Re: Vizio E321VL
Well here is to creative thinking..... NOTHave you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
looking at your boards that's a E320VL not E321VL. I know your board is label E321VL but I had this E320VL mainboard and when I check the system information the firmware was E320VL VER 1409. Unfortunately I didn't copy the eeprom and I sold the TV already.
So I will focus on the firmware and try to access it by using the side control buttons.You need to confirm you have the correct firmwareHave you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
Have Viziio E371E
http://www.tgohome.com/ServiceManual...20BIN%20files/
Maybe compatiblePlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: Vizio E321VL
This is not 2 seconds to black. The backlights on their own will stay on for 2-3 minutes and then shut down. I think this is an energy saving function. I have not been able to duplicate what I did earlier.
I hooked the tv up to the VGA connector on a computer but got no picture.
I then started checking voltages at the connectors to the Main and Inverter Boards. The voltages to the main board all check out. The 24v to the Inverter Board are all there. However, something funny happened when I checked the ground wire which is the first pin from the bottom of the connector. I got a 3.455v reading on ground pin one and two. That was having my black probe on a screw and the red on each ground wire. The third pin up from the bottom is also a ground pin and it has 0.34mv on it.
Does any of this change anything (help) in figuring out this problem?Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
BumpHave you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
I have been completely through the TCon board and checked all of the caps for resistance and none of them look bad with very low resistance all are in the 3k range or somewhere just above or below that figure. I also checked the one component that looked like an LDO regulator, but I could not find a datasheet so I don't know for sure if that is what it is or what I should be looking for in the way of voltages.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
Well you want believe this, but the tv is working like a charm. I guarantee none of you will believe what I finally found to be the problem.
Because I could never get the remote to work, that kept bothering me. I even went so far as to order another IR Board and ribbon cable to see if that was what was keeping the remote from working. Today I was taking the old ribbon cable from the main board and the IR board and I decided I would check it for continuity of the strands. When I looked at the cable closely one end was all messed up with strands overlapping and kinked. I straightened all the strands out and realized they weren't going to stay where I was putting them. I finally decided to cut them off back to where they were stable. When I reinstalled the cable I tried the tv and the set lit up and the menu showed along with the remote working. I took it up stairs to the family room, plugged in the cable and ac and it works perfectly.
I guess this is a prime example of check everything even if you don't think it could be bad. Tom 66, BudM, Retired Caps, Miguel and everyone else who helped with this project, thanks very much. Who would have thunk the IR cable could keep the tv from working?Last edited by killian6pk; 08-05-2012, 04:55 PM.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
Because I could never get the remote to work, that kept bothering me. I even went so far as to order another IR Board and ribbon cable to see if that was what was keeping the remote from working. Today I was taking the ribbon cable from the main board and the IR board and I decided I would check it for continuity of the strands. When I looked at the cable closely one end was all messed up with strands overlapping and kinked. I straightened all the strands out and realized they weren't going to stay where I was putting them. I finally decided to cut them off back to where they were stable. When I reinstalled the cable I tried the tv and the set lit up and the menu showed along with the remote working. I took it up stairs to the family room, plugged in the cable and ac and it works perfectly.
Congratz!Muh-soggy-kneeComment
Re: Vizio E321VL
Thanks, we can add this one to the vault of strange but true fixes.Have you ever stopped to think and then forget to start thinking again?
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
Assuming...7 Photos -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
