Vizio vx42l troubleshooting help.
  • noonehere
    • Apr 2012
    • 6
    • usa
    I picked this monitor up as part of my ongoing quest to teach myself electronics. Near as I can tell, it was the victim of a botched repair.
    First problem it had, was it would go into standby when power was applied. The vizio logo would light amber, then when you pushed the power button, it would go white. You could hear the power supply kick on, but that was all that would happen. I would then have to unplug it to get it to "turn off." After some google searching I found several threads here about regulators on the mainboard. I tested the u33 LDO which was, in fact, bad. Replaced that:
    Then it would power on, and I could get sound. When shining a flashlight through the screen, I could see picture. Ok, backlight time. I cleaned up some horrific soldering botch on both boards, and they are still ugly. Visually the driver chip on the slave board had a pin fried, and I could tell both driver chips had been changed, as they both had flux puddles and pulled up traces. Replaced the driver chip on the slave board, and used a silver pen to re-draw the traces for the driver chips (red boxes in the inverter pics)
    Now, the backlight will power on for about 1-2 seconds, then will turn off. The tubes do not look like they are igniting all the way, as the center of the display never comes to full brightness. Still have sound and picture (with flashlight) The HV transformers all test ok on my multi meter, and none of the caps look like they are bad from the outside.
    Also, the two heatsinks on the powerboard that are circled in red. They are energized (both when on, and when in standby) with 65v ac. That was a bit of a painful discovery. That cannot be normal right? I do not know if they've always been charged; I only got zapped during testing, after re-installing the inverter boards.
    My question is, what should I look at next? Does it sound like bad ccfl's? All the tubes seem to be doing the same thing, and I do not have a spare set of inverters to test with. (unless I could use the darfon board from an insignia I have apart)
    P.S. Anyone know what that 4pin ribbon cable by the master inverter board is?(circled in red) There are traces for a plug on the board, but no plug.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Vizio vx42l troubleshooting help.
    1) I started learning electronics by fixing old broken lcd monitors.
    2) Thanks for doing some research first. Lately, we have had a flood of people who don't research, don't use punctuation or paragraphs, and can't or won't follow directions about uploading pictures.
    3) 2 seconds to black can be
    a) bad caps
    b) bad ccfls
    c) bad ccfl wiring (especially the return wiring)
    d) bad secondary windings on the inverter transformer
    e) blown fuse on one of the inverter boards (if multiple boards or multiple fuses)
    4) More details starting with post #19 at
    https://www.badcaps.net/forum/showthread.php?t=10419
    5) Your inverter transformer should measure around 59 ohms according to
    http://www.lcdparts.net/TransformerD...ProductID=3898
    6) Heatsinks are usually live. Usually the power mosfet is attached to it. The board should be clearly marked hot and cold. Treat anything on the hot side with respect and don't touch anything.
    7) My only suggestion for future posts is to have pics more clear and near 2000x2000 resolution, but not any bigger. Otherwise, great first post and great job of getting the repair done on your own this far.
    --- begin sig file ---
    --- end sig file ---
    • tibimakai
      • Jan 2012
      • 3680
      The Fets show a 8.5K ohm on the inverter boards?
        When you get part of the screen half lit, that means one of the Inverter board is not working, you have the Master/Slave inverter board setup.
        Please supply good close up pictures of both inverter boards. part number as printed on the board will help also.
        Look real close at the IC on the inverter board and verify the resistance reading of all the MOSFET. The boards may need modification kit
        https://cdn.badcaps-static.com/pdfs/...39dfa5950e.pdf
        OK, I did not see the comment about the burnt pin on the IC, that is very common failure, and if some one replaced the IC and the MOSFETs but did not do the mod, then more likely the problem will happen again.
        LG has issued two mods so far, the first mod did not work, so they issued a second mod (mod II), which I still do not know if that will for sure fix the problem or not.
        Was this TV worked on by some one else before?
        • noonehere
          • Apr 2012
          • 6
          • usa
          between 8.4-8.5 yes.
          All the ccfl's are lighting, but only at the ends, they do not seem to fully ignite. Unfortunantly that's about the limit of my cell camera's detail. Board #'s are PNEL-T707A and PNEL-T708A
          My understanding was the mod was to prevent future driver falure. (mine are not modified) I had seen that, but I did not want to install the mod until I had verified them working in current configuration.
          Well I think that may be it. I check the transformers for shorts, and they were all consistent. Unfortunately they were consistently 28 ohms on the secondaries, not 59. So it may be that they are all cooked.
          However my transformers are BJA4B07A23 (A2) rather than the BJA4B07A22 (B) Dunno if that makes a difference. Also, with how badly the work was done on the inverter boards, I would not be amazed that it cooked all four of the transformers.
          Also, thanks for the troubleshooting link! That's a big help.
          • retiredcaps
            • Apr 2010
            • 9271
            1) The inverter secondary pins may be in parallel which might cause "invalid" resistance readings (see below). It would be odd for all 4 transformers to be bad.
            My first application of an actual law from
            http://en.wikipedia.org/wiki/Series_...ts#Resistors_2
            56 ohms x 56 ohms / 56 + 56 = 28 ohms.
            2) I see at least one SMD fuse on each inverter board. Make sure both are good. A good fuse should measure less than 1.0 ohms.
            3) It might be worth changing out the caps on the inverter boards (only 4 total). Use something like Panasonic FM or FC.
            • howardc64
              Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
              by howardc64
              Problem
              Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
              Model & Board Pics
              Conflicting Spec
              Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
              https://www.shopjimmy.com/vizio-gj-2k1...
              10-10-2024, 01:16 PM
            • x_orange90_x
              by x_orange90_x
              01-29-2025, 09:24 PM
            • osrex
              LED DRIVER KEEPS DYING
              by osrex
              Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
              i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
              i have no datasheet at all for the LED lights, all i have is its length.
              long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
              as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
              05-05-2025, 03:36 PM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
            • Awsmessymail
              Vizio E701i-A3 backlight only and now no backlight
              by Awsmessymail
              Hello all,
              I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
              I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
              As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
              02-13-2024, 11:04 PM
