VSX-519V-K av reciever
  • awyatt2
    • Feb 2012
    • 407
    • america
    anyone here ever tried to troubleshoot one of these? dosent seem to be getting power out of the main xformer. i did the reset procedure but it still wont start.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: VSX-519V-K av reciever
    Did you get the SM
    • awyatt2
      • Feb 2012
      • 407
      • america
      yes i found it last night, it seems to be in shutdown. reset dosent help and it wont stay up long enough to test vrs
      • awyatt2
        • Feb 2012
        • 407
        • america
        this one has to wait, have a bad bug. feel too bad to even look. thanks selldoor i do have manual and eyes hurt too bad to try
        • odie34
          Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
          by odie34
          I am a hobbyist (not a professional) so please be gentle...
          I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
          I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
          02-18-2024, 09:11 AM
        • ictc
          Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
          by ictc
          I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
          Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
          The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
          02-25-2025, 12:15 PM
        • kotel studios
          ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
          by kotel studios
          Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
          Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
          I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
          12-14-2024, 10:48 AM
        • MyBrainIsAStrainer
          Asrock H87-Pro4 Rev. G/A 1.04: Power cycling on reset only
          by MyBrainIsAStrainer
          Hi!
          I have a weird one for you. I have a H87-Pro4 from Asrock that power cycles. But only when you do a restart after it was already running!
          Symptoms in detail:
          1. I switch off the ATX PSU for ~15-20 seconds, then switch it back on again.
          2. I press power button. The board boots without issues.
          3. I can shut down the board any way I want (via OS* menu, or pushing the power button - either in the OS or the boot manager).
          4. Push power button again, board boots fine.
          5. This shutdown/powerup can be repeated multiple times without problems.
          6. BUT: If I do a restart instead
          06-25-2023, 02:44 PM
        • masterm
          JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
          by masterm
          TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
          Problem with TV:
          - Netflix stopped working so i tried to do factory reset from the TV menu.
          - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
          - After waiting for some time, the TV went into a boot loop.
          - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
          04-30-2024, 03:03 AM
