Hitachi 42LDF30U RANDOM SWITCHING OFF
+ More Options
Posts
  • shepp
    • Mar 2012
    • 377
    • England
    Re: Hitachi 42LDF30U RANDOM SWITCHING OFF
    ive messaged them but they havent messaged me back,
    does anyone know if this might work...http://cgi.ebay.co.uk/ws/eBayISAPI.d...:X:RTQ:GB:1123
    the numbers arent the same but the connectors are right and the tv is a 1080p, the t-con connector is the same and so are the others,
    my board is a 17MB35-1 V2 020708 20458174
    the guy says i can return it but at postage cost(usual)
    the only same board as mine i could find was for Β£85!! so if this might work its worth a try
    • shepp
      • Mar 2012
      • 377
      • England
      ive just read through both service manuals and they are the same manual same specs and pin outs etc.....just differant model of tv
      • vinceroger69
        • Mar 2012
        • 6714
        if it was me i would take the risk and buy it. as you have said its either try to fix it or refund the buyer.
        • shepp
          • Mar 2012
          • 377
          • England
          ive got to refund the buyer anyway now, but 42" normally sell pretty quick, so ive just ordered the other board, i will let you know if it works when i get it, it should do...the manual is exactly the same but with differant model numbers on the first page, so i would expect the software to be the same just a newer revision so fingers crossed,
          im emailing Hitachi now to see if it will cross match
            I find it kind of difficult to sell >32" TVs except over eBay.
            • shepp
              • Mar 2012
              • 377
              • England
              #26
              ive still got a 32" thats like brand new here, but no one wants it, but i havent listed it on ebay yet, was trying to sell it without the fees but with no joy yet
              were as when ive managed to fix a 42" its normally out the door within a couple of days
              apart from this one...lol
              • shepp
                • Mar 2012
                • 377
                • England
                #27
                HITACHI : i need to use the correct part
                SHEPP : but if the t-con is the same in both tvs and the main boards are the same surely the same software will work will it not?
                HITACHI : although the parts maybe the same the lcd panels are differant and require differant software, you need to order the correct part
                from charles hyde (Β£90 for main board but it is new)
                but unfortunately for me ive ordered a main board now so well see when it comes....i really hope it works so i can stick 2 fingers up at Hitachi! ha ha
                but my hopes have faded since there last email but it came too late!
                  Most TVs will still work with the wrong main board but the picture will be screwed up, usually just colours wrong. You can sometimes fix this from the service menu.
                  • shepp
                    • Mar 2012
                    • 377
                    • England
                    #29
                    ive looked in the service manual but it doesnt make much sense to me with all the settings, what does what etc, so i might need some help, but ill let you know when i get the board....hopefully tomorrow, it will be good if i can set it up with the service menu if it doesnt work properly
                    • shepp
                      • Mar 2012
                      • 377
                      • England
                      #30
                      Picture was sound, but the control for the buttons must be differant because it keeps turning volume up and down on its own, even with the buttons un plugged, but the board itself is actually differant, and now the plug for the buttons has broke on me! so this ones going from bad to worse!...due to my own stupidity!
                      im gonna have to correct my mistakes by paying through the nose now for a replacement board and solder the wires for the buttons into place on the new board when it comes
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • Vspeed
                        LCD 31MU97Z displays random lines randomly
                        by Vspeed
                        I have this monitor which had the known issue with the corrupted flash. That is solved, now, after some time it started to cut the image from time to time and just display grayish random vertical lines. After some minutes the image usually comes back, until it does the same again.
                        I took it apart and the only think that I noticed was ZD1 protection diode on the TCON board reaching 90ΒΊC when it's showing this erratic behavior. I measured the voltage on the fuse right beside it, and is measuring 15.3V (under load). Without the TCON board connected, the connector measures 18.3V....
                        01-22-2023, 02:26 PM
                        by sam_sam_sam
                        After all of...
                        07-13-2024, 08:14 PM
                        DVR camera recorder switching power supply capacitor failure really
                        by sam_sam_sam
                        These cheap non brand capacitors at it again
                        Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                        Well at least I have the cameras back on line I to try the...
                        01-22-2022, 06:28 PM
