Samsung LN40A630 display question?
+ More Options
Posts
  • mu2
    • Oct 2009
    • 217
    There is a Samsung LN40A630 being offered on my local craigslist.
    The owner says the display isn't physically damaged but the left side of the picture is normal and the right side "lags" slightly.
    Any thoughts on the defect? T-con? Panel? Main Board?
    I've never seen this problem and would like some advice before I make an offer.
    Thanks.
    Mike
  • truep
    • Aug 2010
    • 373
    Re: Samsung LN40A630 display question?
    Maybe a tcon, but could be a panel. T had a sony with a similar problem, lagging with a redish tint and it was the panel. The sony had a samsung panel.
      Most likely a panel problem, which may or may not be fixable.
      • BoJaXz
        • May 2013
        • 19
        i have a question, what are the small silver ribbon cables going from the tcon board to the driver boards and where can i get them? there are 4 of them.
          Ribbon cables. Probably you can buy them from Samsung, or from someone who has broken up this TV.
          • BoJaXz
            • May 2013
            • 19
            I tried Samsung, not on the parts list :-(
            • newtothis
              • Mar 2013
              • 1556
              • england
              Put a picture of the cables, I might have some
              • BoJaXz
                • May 2013
                • 19
                At work, I'll post some when I get home. I was also gonna try a local TV repair shop and see if they have some.
                • BoJaXz
                  • May 2013
                  • 19
                  this is a picture from the back of the tv, i can take one out if you need and post it.
                  • BoJaXz
                    • May 2013
                    • 19
                    ys0828 1915 is the number on it. i can get some from the netherlands off ebay. but that would cost me almost $30 for one freakin cable
                    • kevinm34232
                      • May 2012
                      • 1884
                      I have an update on this model. Tv was dead with 1 long blink from power LED.
                      Replaced main board and TV came on normally, but saw tab bond like symptoms as described above, picture would change as screen was flexed.
                      Relatively easy to get into panel on this one, and put some heat xfer foam on very top left corner bond, front side, snugged down screws and looks good now.
                        Great job, so which brand of heat xfer pad and how thick is it?
                        • kevinm34232
                          • May 2012
                          • 1884
                          Well LOL I just ordered what you had recommended yesterday
                          http://www.digikey.com/product-searc...ords=BER165-ND
                          but what I have been using is the rubber pads from scrapped TVs like the big pads under Y-Mains in plasmas. This one appears to be holding up, but I'm taking back a 46" Vizio from a customer that unfortunately did not hold up. I may give it another go with the new thermal pad, but I think in these cases it's more a matter of getting the correct pressure on the right spots and being able to reassemble the TV without it changing, do you agree?
                            Well I am glad that not just me having good success with the same pad I use, both 52" are still working since last November.
