Polaroid TLX-03210B not responding.... at all
  • wohdin
    • May 2012
    This is NOT the "smoking/bulging cap" issue, or at least not the one that everyone else seems to have. Recently a TV stopped responding ENTIRELY to ANY sort of input after having a VGA cable plugged to my PC from the graphics card (I don't really think this was the cause of the issue, though - how would that even work?). I plugged it in, and for a moment it worked fine - it displayed the image from my PC, albeit in the wrong resolution, and it didn't seem to show any problems. But I turned the TV off for a moment while I went to the bathroom, and when I went back, I tried to turn it back on, but... nothing. The LED was red, and it did nothing. I tried the power button on both the TV's panel and the stock remote that came with it, and nothing. I tried power cycling it to restore it to factory settings, and nothing. I've even taken it apart to check for problems, and I checked and reconnected the connectors of the control panel and everything else, and nothing had any noticeable problems. I don't really know what a "bulging capacitor" would look like, but I didn't see anything that looked particularly abnormal.
    All it does is sit there, with the LED on red, and does not respond to anything. At all.
    Any suggestions for what the problem might be, or what I should do to get to the bottom of the problem? I'm not exactly an experienced electrician, but I've "serviced" several smaller devices (video game consoles, VCR/DVD players, PCs) in the past, and never had a problem as weird as this before.
    This TV is about 2 years old and I'm pretty sure it's well past its warranty.
    [e] pics: http://www.mediafire.com/?llzu2o25nkqc5
    Re: Polaroid TLX-03210B not responding.... at all
    Can you take some pictures of the boards in your TV? These Polaroids (and in general the Proview chassis) has a problem with the main board cage getting mis-seated from the main connector.
    • crtfool
      • Jun 2010
      • 82
      This is a very common Polaroid defect - aka "the red light of death". The problem is the control board - nobody has been able to figure out what goes wrong with it. Your best solution is to get a working board from a set with a cracked screen. Several people have posted horror stories from boards acquired on eBay. I also had difficulty with 1 board that I got on eBay, but the second board worked perfectly. This is the part number: 200-107-GT321XA-BH
      • wohdin
        • May 2012
        http://imgur.com/a/yVeGr#0
        Here are some pics of the boards, but imgur seems to have shrunk them. I'll mediafire them in a bit.
        • colormebad
          colormebad
          • Dec 2010
          • 114
          I have all boards for a Polaroid, will have to check to see if its the same model or not..
          • jean luc ferre
            laptop hp g72 b52sf screen problems
            by jean luc ferre
            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
            i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
            06-07-2025, 03:27 PM
          • Hondaman
            USB problems?
            by Hondaman
            Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
            (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
            I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
            08-12-2024, 03:26 PM
          • clabr
            Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
            by clabr
            Need help to solve some problems with this laptop.
            After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
            After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
            Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
            Before this had happened I observed some other problems:
            When I tried replacing original mecanical HDD with a SSD HDD could not get them...
            12-02-2021, 08:09 AM
          • ktmmotocross
            PS5 Slim - no video, butchered hdmi, after replace still no video, diagnostic said APU was overheating and now not responding
            by ktmmotocross
            Have this PS5 Slim with no video, HDMI connector was horribly butchered. but after replace i have no video. diagnostic said APU was overheating and now not responding,
            checked fuses and all are good
            any hint?...
            07-24-2025, 02:12 AM
          • questore
            MS-16R61 Rev 2.0 EC not responding after repacement
            by questore
            Hello adventurers
            I have this board and it came from a friend with a shorted EC.
            I have ordered a new one and replaced it.
            Now i have 4 Milliamps draw on pluging
            3VALW and 5VALW present (i know nothing about RSMRST and ECRST because web only has boardview for 16r3 and this modell looks competly different)
            For EC flash i need KSO3 KSI4 KSI7 KSI6 KSI5. These are all 3.3v EXCEPT KSO3 is 2.2V
            I have checked the FFC cable connections and they are OK.
            I have removed and Reballed the IC again, but no change.
            Do you have idea why EC not responding...
            07-16-2025, 02:46 AM
