Philips 47PFL5603D/27 lcd panel replacement
  • tieny
    • Feb 2012
    • 478
    Hey guys, I have a cracked screen philips 47" 47PFL5603D/27 and I recently found a philips 47" 47PFL5704D/F7 with lcd screen good and intact but no power. I was wondering if the lcd panels would be compatible with each other? Or if the boards are compatible? If so then I could finally swtich them out and repair my cracked lcd tv.
    Anyone have any information about these two philips lcd models before I proceed with the purchase?
  • richpart
    • May 2012
    • 42
    Re: Philips 47PFL5603D/27 lcd panel replacement
    Do the panel stickers match? If not, it's risky. The variance lies in the small control boards mounted in the top of the panel. These can be changed during production runs. The circuitry for the main board and T-con have to be compatable or more damage will result.
      You need to match the model and the REVISION number, since you will be mounting the T-CON and the inverter board/s on the new panel, the mounting holes and electrical spec will have to match your old panel.
      • JayFixesIT
        LG 65UH9500 TV Panel replacement seal?
        by JayFixesIT
        I am in the process of replacing the backlight boards on the LG 65UH9500 TV. It requires the separation of the front glass/panel to get to the boards. The panel is help on to the frame with some kind of strips that I cannot reuse to adhere the screen to the frame. Anyone have any experience/Ideas on what I can use to securely hold the 65" Panel to the frame. I would hate for the panel to fall face forward. Thank you in advance....
        09-08-2024, 11:15 AM
      • bohaboha
        PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
        by bohaboha
        Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
        how to fix it thanks
        02-05-2025, 09:23 PM
      • Guerilla3
        Philips 32PFH4101 - bad panel?
        by Guerilla3
        Hello guys, I need your opinion whether this panel is bad and should I pursue it further. Third photo: left side t-con cable disconnected.
        11-22-2024, 12:54 PM
      • howardc64
        LG 49UJ6500 LCD panel lighter band that goes away
        by howardc64
        49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
        Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
        02-19-2023, 12:13 AM
      • triplefour
        SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
        by triplefour
        TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
        tcon is built into mainboard.
        Only one cable goes to panel boards.
        there is a cable from one panel board to the other that links them.
        cost cutting measure that results in us having harder time to diagnose.
        removing the link to the second panel board allows TV to stay on with stable backlight but no image.
        used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
        07-28-2022, 07:59 PM
