Jvc lt32a61sj/bj audio but no picture
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Jvc lt32a61sj/bj audio but no picture
    Originally posted by selldoor
    I dont think we can do much until it is established if it has the TRAP switch.
    It doesn't appear to have any HDMI ports, so it's probably pre-boobietrap era..
    • MISTERG
      • May 2012
      • 15
      • greece
      The picture is taken frm the net, not me measuring ,just to show the eqpmnt as i was out at the office and not at home.
      the set has only a dvi port no hdmi existing
      i tested the PSW board with the multimeter dial set at 200V DC
      • MISTERG
        • May 2012
        • 15
        • greece
        continued
        I followed guidance for measuring from ehow com
        http://www.ehow.com/how_8490454_test...ssipation.html
        now i will try to desolder the forth green cap that showed a zero volt value and place the new one.. hope i am lucky
        Thanks for all the info.
        • MISTERG
          • May 2012
          • 15
          • greece
          After a "while" i decided to pick it up from the last step i did.I have changed 4 capacitors on the psw. It didn;t help. I checked the voltage output from the psw it reeds ok (as indicated on the psw).
          (1)I haven't tested the resistors yet and the diodes on the psw, i will do it today. (2)I also saw in an other link that little triangle fuses may be the problem on the main board?..
          So do you think that last two actions will help?
          • MISTERG
            • May 2012
            • 15
            • greece
            i removed the pwb and i noticed that smthng is damaged in Q9 >Q9 T0507-00009A TRANSISTOR could that be the troublemaker to the set? to be frank i dont know what a transistor actually does.
            also i noticed one capacitor a bit loose and i am thinking to resolder it
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              Q9defently needs replacing imo. C8 also looks like its got hot? or just the pic
              • MISTERG
                • May 2012
                • 15
                • greece
                #27
                Thanks for the help! C8 seems hot , you have an eye like a hawk , i had to zoom twice to see it. I called the local service store and gave them the Q9 T0507-00009A TRANSISTOR detail, but they reverted that this is the manufacturer's id of the spare part and not its "commercial" name/type i.e. npn etc .Does anyone know what is the commercial name/type , as JVC service in Greece stopped its operation a couple of years ago, so i am not hoping for an original part. I assume they will say the same for the C8.
                I attach the service manual/spare parts if you can see smthng more
                Again Many thanks for the info provided in the forum.
                p.s. With the information given in this forum, I had restored successfully my pc motherboard (bad cap, exploded top).
                • MISTERG
                  • May 2012
                  • 15
                  • greece
                  #28
                  Keep posting to myself. I am determined to resolve this.
                  Found with a lot of internet search that T0507-00009A TRANSISTOR has most probably the commercial name as the attached file. I made an order on this , it will come within the next 15 days..hope it works.
                  But with C8 the manufacturer says it is a capacitor C8 T2203-FC104E C CAPACITOR 0.1uF 50V K?!!! Could that be, with that shape? or is it also a transistor? Btw there is no such capacitor ( i mean the shape) in the electronics shop.
                  Please help.
                  • samson7point1@yahoo.com
                    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                    by samson7point1@yahoo.com
                    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                    The player processes the audio signal using two different reference frequencies. The "R"...
                    04-30-2024, 11:22 AM
                  • IAmOrion
                    LG55UB850V no picture or audio, just flashing LED's help please?
                    by IAmOrion
                    Hi members, I came across this forum when searching a fault on my LG 55UB850V TV.
                    Rather than hi-jack another members post/thread I thought I should start my own even though it's an almost identical issue.
                    The thread I refer to can be found here:
                    https://www.badcaps.net/forum/troubl...-s-help-please
                    My boards are the same, and my issue it the same. I have NO Picture and NO Sound. Nothing. When first turning on the TV at the...
                    01-28-2024, 06:50 PM
                  • Tr0ll
                    by Tr0ll
                    Original T-con:
                    First replacement T-con:
                    10-07-2023, 07:48 PM
                  • JJAAMM
                    by JJAAMM
                    Problem
                    07-06-2023, 06:01 AM
                  • WayOfTheRoad
                    Vizio D55x-g1 (55" 4K, no backlight, has Audio and picture)
                    by WayOfTheRoad
                    Hello, everyone. A neighbor was throwing this TV away for "not turning on" so I asked for it and they gave it to me for free since Vizio gave them a new TV under warranty.
                    I'm pretty proficient with electronics in general but this is the first TV I've ever tried to fix. I strongly suspect bad LED lights but figured I'd post some info and see if those of you more experienced with TVs can confirm my suspicion before I move forward. Some photos and measurements below:
                    The power supply only has two outputs, one output cable going to the main board and the other...
                    03-31-2022, 12:22 AM
