Wharfedale LCD42F1080P comes on but then picture turns off
  • shepp
    • Mar 2012
    • 377
    • England
    Re: Wharfedale LCD42F1080P comes on but then picture turns off
    i think thats the coil winding off the transformer tho not the bulb
      Originally posted by shepp
      or shall i just disconnect them one by one and see if it stays on?
      Do this in a dark room, if the screen flickers with each individually the bulb is probably good.
      • shepp
        • Mar 2012
        • 377
        • England
        just gone through em all one by one and they all light up no flickering, on then after a couple a seconds go off again, i have noticed one transformer seems to make some noise, starts buzzing then sqeals before the light goes off
        not sure if i should just buy that ebay item or not, coz its hard to source the transformers unless i get them from u.s but there $20 each i think so for £35ish i could get the ebay one? unless i could get a replacement transformer equivilent over here?
        • shepp
          • Mar 2012
          • 377
          • England
          just noticeed this, do the ribbon cables just push in? cause i cant see a clip or any thing on this type? and it wont push in any further
          help please
            Those look about right.
            • shepp
              • Mar 2012
              • 377
              • England
              #26
              o right do they just push in and pull out then?
              only all the other 6 look like the one on the right
                They just push in... sometimes there is a latch to hold them in, but not always.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #28
                  the one you have highlighted does look a little further out when you pull the ribbon cable out is the end of the cable ok no tracks lifted? stopping it going all the way in may be shine a light in the connector just to comfirm there nothing out of place in the socket? bent pins or whatever in there.
                  • shepp
                    • Mar 2012
                    • 377
                    • England
                    #29
                    ok thanks mate, think i might have to bite the bullet on this one then and order the invertor boards
                    ill check that now vince
                      Before you do that... Check the ON/OFF and DIM pins on the inverter.
                      • shepp
                        • Mar 2012
                        • 377
                        • England
                        #31
                        which ones are they? the invertor to tcon?
                        i check the on/off voltages before and they were fine and also the dim was getting a reading, just gonna whip cover off the t con now just to check the ribbon cables in properly, i had it working for a short time(5mins) the other day until i hit the menu button and it went off again
                          Inverter to PSU. Since it is intermittent, I would suspect a cold joint or a loose connection.
                          • shepp
                            • Mar 2012
                            • 377
                            • England
                            #33
                            just been through a few but gonna have to wait til later now cause the Mrs has got family round so ive been told ive got to be social...lol
                            will report back later on
                            • shepp
                              • Mar 2012
                              • 377
                              • England
                              #34
                              bought new invertor boards off ebay and just replaced the master and its up and running now, thanks guys once again for the input, the board has got a hot spot on it so im guessing its burnt something out, just hope i can sell the slave and get some money back for that
                                The faulty master is worth money too as the majority of the transformers on it are probably okay.
                                • shepp
                                  • Mar 2012
                                  • 377
                                  • England
                                  #36
                                  do you think i should list em both or seperate on ebay?
                                    List them separately... only parts resellers will want the faulty one... you might get a few quid for it.
                                    • shepp
                                      • Mar 2012
                                      • 377
                                      • England
                                      #38
                                      thanks tom, will do that
                                      • comptek
                                        • Aug 2013
                                        • 606
                                        • uk
                                        #39
                                        hi this is my first post so please dont shoot!
                                        i have a Wharfedale LCD42F1080P and i am having issues with it
                                        i turn it on after a few mins you can see a faint flickering even more so when its a bright background during an advert for example
                                        then after a while picture goes but still have sound, i can turn it off and on again and it will do the same
                                        i measured the inverter side and im getting 21.?v when lit and 23.?v when the screens gone off and sound still on... im guessing its a flakey power supply or main inverter i was given it after someone tried fixing it
                                        • comptek
                                          • Aug 2013
                                          • 606
                                          • uk
                                          #40
                                          sorry i forgot to say thank you
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • ItepK
                                            LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
                                            by ItepK
                                            Hello everyone! I've found this television, and I began troubleshooting it.
                                            First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
                                            I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
                                            After the recapping, all the voltages stableized, however, the issue in the title still remains.
                                            I could...
                                            01-03-2025, 09:01 AM
                                          • burbutsalos
                                            55" QLED QE55Q60T Turns on after 1 minute the picture goes bad and get in boot loop
                                            by burbutsalos
                                            Hello ,
                                            The issue with this set is that it turn on just fine and after a minute or so the picture shows either vertical lines or turns half black and from that point on starts a boot loop.
                                            If a let the unit to cool down for a minute the same pattern starts again. i had exactly the same mainboard as a spare and replaced it but nothing changed.
                                            Any ideas what to check?...
                                            12-12-2023, 06:06 AM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
