I'm going to take a gamble on this a replace the logic board. I recall yesterday when I probed the left side ribbon pins that the waveform started but then flat lined after a second or two after power up.
Note: This test function may not be available on all models
• Step 1- With the Main PCB removed, short pins 1 & 5* on the 24P ribbon cable to the SMPS from the main PCB to turn the panel on. This will turn on the secondary voltages of the SMPS. Shorting the POWER ON connection to ground is the same as the power on from the power switch.
• Step 2 - Carefully short pins 3 & 4 of the quad connector on the Logic PCB together. When the panel is powered on, the PDP will automatically “play” the internal test patterns stored on the Logic board that would normally be accessed only through the service menu. This will force the logic board into a loop where the internal test patterns will be displayed in sequence.
• Step 3 - After the proper pins are shorted, apply power to the AC input. The TV will power up by itself and if all is well with the logic, X, Y buffers and address boards, the panel will “play” the test pattern loop. If everything looks normal the possible problem is the main board which is the only thing left not in the circuit.
*ALWAYS check the service manual for the correct PS_ON and GND connections.
SMPS
Short the PS_ON and GND pins on the ribbon cable connector from Main Board to SMPS (24P)
Short pins 3 & 4 on the Logic Board with a 4 pin test terminal Logic PCB
Rrrrrrrrr... Tested the logic board off the tv. Hooked up 5.2v via my variable power supply. I probed the ribbon pins you said. When it was on the Tv I wasn't getting the waveform but now I have them. I'll upload the snap shots of oscilloscope reading and waveform
so true i just like to finish the job, waiting or wrong parts sent/faulty is really annoying imo.just read your posts hopefully the replacement boards will fix your issues never worked on a plasma my self but toms helping you as best he can so i am sure you will fix it soon.
That's a affirm.. Toms been a big help. And your right about the wrong or faulty part. And I believe I was sent a faulty Y-main. Going to send it back since the seller warranties it.
They're probably fets on the PSU, they could be a problem but I don't think they are the actual cause, if that makes sense.
