Toshiba 32AV502R
  • Vizor
    • Nov 2011
    • 215
    Toshiba 32AV502R
    Model: Toshiba 32AV502R
    Issue: Picked this tv up for 15$ worked one day and next didn't or so i was told
    Symptoms: When Fully Powered down and turned back on Power comes on, very top of the screen tries to light up very very very quick and dim green light is flashing on the TV and doesn't stop flashing.
    All voltages are outta whack hear noises coming from the power board here where i have a video to help.
    163.8 coming off the main cap when powered on however.
    http://www.youtube.com/watch?v=KU6opm7Tdd0
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Toshiba 32AV502R
    1) What is the DC voltage across the startup cap, C207 (right by the SP2)? Is it steady or fluctuating?
    2) What is the SMPS IC part number right by the startup cap?
    --- begin sig file ---
    --- end sig file ---
    • Vizor
      • Nov 2011
      • 215
      Voltages all over the place unstable.
      CHN
      Viper27L
      KV3848
      • retiredcaps
        • Apr 2010
        • 9271
        If you have an ESR meter, check the startup cap, otherwise try replacing the startup cap first, it is the easiest.
        • retiredcaps
          • Apr 2010
          • 9271
          Viper27L
          1) Refer to figure 3
          https://cdn.badcaps-static.com/pdfs/...9c18eaaac3.pdf
          2) See if GND is shorted to VDD (pin 1 to 2).
          3) Measure the DC voltage on pin 2 (using pin 1 as GND). Be specific in the range that it is wildly fluctuating.
          • retiredcaps
            • Apr 2010
            • 9271
            Be specific in the range that it is unstable. With your above description, I have no idea if is unstable between 1V and 166V.
            If your multimeter has min/max, use to see what the lower and upper range.
            • Vizor
              • Nov 2011
              • 215
              Replaced C207 and no change. the blueish thing next to the transformer is the biggest noise i hear PHSl04J 800VHoB
              • Vizor
                • Nov 2011
                • 215
                5.34v
                max 13.46v
                • Vizor
                  • Nov 2011
                  • 215
                  5.34v
                  max 13.46v
                  same thing on the IC also.
                    Check the resistor and diode feeding off the transformer for the cap (on primary side.)
                    Check all diodes on secondary for shorts.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      On page 6 of the pdf, the VDDon is 14V DC typical. The minimum is 13V and max is 15V. So it looks like the SMPS IC is trying to start if the max is 13.46V DC. This is why the actual readings are critical.
                      Since you changed the startup cap, this means that there is probably a shorted diode on the board causing the SMPS to startup, shutdown, startup, shutdown, etc.
                      I see at least two diodes right by the startup cap, possibly 3. There is also another underneath the big yellow transformer. Test them all and others that you find with your diode test function. If one is shorted, it will give the same reading in both directions.
                      If you cannot find a shorted diode, then the SMPS is the next suspect which is why I asked you to check for a short between GND and VDD.
                      edit: Ahh, tom66 beat me while I was reading the datasheet.
                      • Vizor
                        • Nov 2011
                        • 215
                        TVS1 Dead/Zero nothing.
                        • Vizor
                          • Nov 2011
                          • 215
                          D500 is Bad and D203 is Open
                            TVS1 is a surge protection device - it is normal for it to appear open circuit on a typical test.
                            However D500 is probably the fault if it appears short circuited. Does it?
                            D203 -> could be faulty, but please remove it and read off the part # so we can tell if it is a TVS or otherwise.
                            • Vizor
                              • Nov 2011
                              • 215
                              Small one: PS!010R Dec 9019
                              Big one: 09016 SB540
                              • Vizor
                                • Nov 2011
                                • 215
                                Can't seem to find them on Digi
                                • S2udio
                                  • Feb 2012
                                  • 16
                                  Maybe these
                                  If you can decrypt the right one
                                  https://cdn.badcaps-static.com/pdfs/...cccfb3af1d.pdf,
                                  and this for the big one,
                                  https://cdn.badcaps-static.com/pdfs/...f3ff9c0fdf.pdf.
                                  Both readily available
                                  Most of the time things ain't what they seem to be
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    @s2udio2
                                    "Most of the time things ain't what they seem to be "
                                    You may be correct but why isn't the small one ( PS!010R) of these:
                                    https://cdn.badcaps-static.com/pdfs/...9c194b055a.pdf
                                    • Vizor
                                      • Nov 2011
                                      • 215
                                      lol i have no idea what they are either i just wrote down what i see.
                                        That D203 may be the Snubber diode (about 200V rating) which in parallel with the primary winding of the transformer, it will read low Ohm due to the low DC resistance of the winding. Verify if the Diode is in parallel with the transformer winding.
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          09-06-2024, 05:33 AM
