hitachi p50h401 ton or logic controller short
+ More Options
Posts
  • awyatt2
    • Feb 2012
    • 407
    • america
    anyone here ever had exp with the hitachi logic controller, mine is shorted i unplugged it as ser manual suggests and it will hold on within seconds after it is plugged in the ps shuts down. i would like to be able to do a repair at component level. i don't like board pulling. the diodes and caps check out so it would have to be a chip. i will post pics of the board later today.
  • awyatt2
    • Feb 2012
    • 407
    • america
    Re: hitachi p50h401 ton or logic controller short
    should say tcon not ton a typo i hate laptops!
    • simplytrini
      • Jul 2011
      • 73
      Hi awyatt2, what exactly is the tv doing to assume that the Logic controller is shorted. Are you able to explain the symptoms some more? I worked on a few of these Tv's recently and might be able to help.
      • awyatt2
        • Feb 2012
        • 407
        • america
        when i remove the connector from power supply the set has sound and the ps stays up if i plug up the logic controller then the ps shuts down. no backlights no pic no sound with everything connected the one that makes the difference is the logic board.if i totally remove the logic board then the ps will shut down with blinking light. about 99% sure the problem lies here.
        • cashkennedy
          • Aug 2011
          • 668
          I would sugest testing the regulators if there are any on the tcon. and try to detect if when its connected there is a short to ground (leave the tv off, but just measure the fuse to ground if there is a fuse on the tcon.)
          The only way the tv can run without the tcon, but shut down when it is connected is probably a ground causing it to draw a lot of power.
          Granted i would never , never try connecting a tcon while a set is running.
          Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
            Ceramic caps on T-cons tend to short a lot.
            • awyatt2
              • Feb 2012
              • 407
              • america
              i didnt connect while running just failed to mention it, i do agree the set will run with it disconnected with sound channel and input, use antenna and dvd to verify, no backlights no display, without tcon this is normal according to ser manual. no regulators, and only a few ceramic smd caps, the lytics pass esr and vom tests. mostly chips on it.
                http://www.shopjimmy.com/hitachi-fpf...ctrl-board.htm
                Are you taking about this logic board? I have never seen T-CON board without some kind of Regulator IC, or switching power supply IC on the board.
                • awyatt2
                  • Feb 2012
                  • 407
                  • america
                  yep and i found the ldo regulator but its not shorted
                  • simplytrini
                    • Jul 2011
                    • 73
                    Sorry to possibly sound repetative but is the red light on or is it the blue light on when everything is connected? Let me know
                    • awyatt2
                      • Feb 2012
                      • 407
                      • america
                      blue light, sound no pic or backlight, vcc and vs are missing voltages at ps. the logic or tcon is not the fault. i just replaced it, unplug the wire harness from digital and does the same as unplugging tcon. much farther and it will be the display. i will remove the digital board tomorrow and look for a short there. something is holding the vs and vcc down, and its not the power supply at fault.may also try disconnecting display just to see before i tie any more money in it. a friend had a spare tcon known to work same set so we ruled that out. he didn't have the digital board though,tried his power supply as well. both supplies work in his set.
                      • awyatt2
                        • Feb 2012
                        • 407
                        • america
                        the blue light is on until the set kicks off about the time the sound comes up.when it goes off no light at all until you reapply power.
                        • simplytrini
                          • Jul 2011
                          • 73
                          ok, not sure if you tried this, unplug the upper and lower s-dr modules from the sustain board (the two longer slim board to the left when looking a the tv from the back they have about 10 buffer chips on each of them). let them hang freely away from the tv and power the set up. if the set powers up and stays on then we know that the sus modules are good. then plug each module (S-dr boards) in one at a time at this time only half the screen should be lighting. If one of the modules are bad it will just shut the tv off again and that should be your issue. This has seem to be a very common issue on this model. I have had 2 exact sets with this issue in the last 2 months. please let me know if this helps. if you have any questions please let me know. take care.
                          • awyatt2
                            • Feb 2012
                            • 407
                            • america
                            been there already nothing changed. the cable from the logic to the neptune digital board when unplugged does the same as when i unplugged the logic. i dont know if i'll spend another 100 on it. but i may ride over where i got the logic board and try my digital board in it. it has to either be there or the display. haavent tried to check the digital yet but i did read a couple of surface mt diodes that were very low.
                            • awyatt2
                              • Feb 2012
                              • 407
                              • america
                              alright, here is where i am now, the neptune dig main has three diodes bad, one open and 2 shorted they all are marked 5480 a smd diode looks like a rectifier. i cant reference these as the ser manual i have has no parts listing for them. the board designation is dg01 and dg02 and dtp1. any help as to deciphering them. i already emailed cust ser. but don't expect to hear back anytime soon. thanks for the help guys. used to work in a shop on crt days. now i'm learning, dont do it for a living.it is a hobby.
                              don't care how many times you fix a set, no feeling like throwing the switch and firing it up, working as it should.
                              • awyatt2
                                • Feb 2012
                                • 407
                                • america
                                no help from hitachi, call customer assistance and wait to go thru the automated system,then they refer you to a service center. well no more hitachi's allowed here
                                • simplytrini
                                  • Jul 2011
                                  • 73
                                  Did you figure out the components you are looking for? what are the part location numbers of the diodes?
                                  • simplytrini
                                    • Jul 2011
                                    • 73
                                    Not sure if you have this but it might help.
                                    http://www.fixdevice.com/smanuals/file/36680.html
                                    • awyatt2
                                      • Feb 2012
                                      • 407
                                      • america
                                      two messages up diode markings and location numbers, think they are schottskys look about 2 amps or so but stilll unsure. the service manual download has no schematics.already got one wit at least partial schematics this one has none. we are trying.
                                      • cadiman
                                        • Mar 2010
                                        • 397
                                        This p50h401 plasma tv has 99% failure of buffer boards and bad caps on secondary of power supply.
                                        I normally start with these tvs by removing the buffer boards then powering up the tv.
                                        I have seen the buffers take out the y drive and then take out the power supply.
                                        These tvs are harder to troubleshoot than the l/gs and other models.
                                        If the screen lights up when powered on than I would say you are on the right track.
                                        • OOF DIO
                                          ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                                          by OOF DIO
                                          (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                                          (Had 3 problems, now just 1)
                                          I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                                          I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                                          I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                                          04-19-2025, 05:03 PM
                                        • MarkC1970
                                          Short circuit on XBOX controller - Model 1914.
                                          by MarkC1970
                                          We have a XBOX 1914 controller that has shorted the 3V3 to J2 (aerial connector). If you unplug the aerial, the controller boots and connects. It seems stable without the aerial plugged in but it is not ideal.
                                          The schematic is on https://www.acidmods.com/RDC/XB1/Sch...OME_VALUES.pdf
                                          I have little to no understanding of these RF transmitters and so I am unsure what has failed. Currently, T2 is short on Pins 1 to 2 and RFF2 is also short on Pins 1 to 2. This is how the 3V3 is getting connected to J2, clearly one or both of these components are faulty....
                                          06-02-2025, 11:06 AM
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • master3112
                                          ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                                          by master3112
                                          I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                                          When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                                          10-29-2024, 09:32 PM
                                        • Guest
                                          A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
                                          by Guest
                                          Hello all!
                                          Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
                                          After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
                                          09-26-2024, 03:31 AM
