Eliminating the inverter board
  • hansen01
    • Apr 2012
    • 7
    Re: Eliminating the inverter board
    Good news. The lcd and sound still run without the inverter. Makes sense. The only thing connecting the inverter to the main board are two connectors with a bunch of grounds, an on/off, and some other things (VIN, Vsel, VEPWM, VIPWM). No clue what those are. I suppose they are to control the light level.
    As a side note I may have found the original problem. There is a tiny fuse or something that seems to be burned out on the main board. It bridges away from one of the connectors coming from the inverter. I noticed it looked a little burned when I first opened the tv up but really took notice when it sparked every time the ccfls tried to light up.
    I suppose if anyone knows what this is I could try to fix it. Otherwise with that issue (which may not fix the problem) plus a new ccfl bulb it may cost the same to install leds.
    If I do install leds all I need to do is figure out which is the hot wire on that connector.
      That's an inductor
      Value ~1-4.7µH 1206.
      • hansen01
        • Apr 2012
        • 7
        Any consistent reason why these go bad.
          Under sized, cold solder joints, shorted load?
          • hansen01
            • Apr 2012
            • 7
            That sounds like a generic answer. :-)
            BTW: Anyone have a good led supplier. I've shopped around but can't really find that "you can find any led here" type of place.
              Well it cannot not any more generic than that, all three of the above can cause it to burn up.
              • cashkennedy
                • Aug 2011
                • 668
                If theres a short on the board replacing the inducor will be dangerous as it will likely explode again once you try the monitor again.
                Im thinking , though budm knows more then me, that you should try testing the dc voltages to ground with the board disconnected and your meter on resistance? Try aranging the probes in both orders (red on ground vs black on ground)
                If you are getting really low resistances from the voltages to ground then there probably a short. I think under 1000 ohms would be a bad sign?
                If the part just went bad cause it was a little undersized / low quality, then replacing it should be fairly safe ... as in it will last a few more years
                Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • lostone
                  Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                  by lostone
                  Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                  First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                  When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                  05-19-2024, 11:40 AM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
