toshiba regza no picture
  • cashkennedy
    • Aug 2011
    • 668
    Re: toshiba regza no picture
    I posted before tom explained.
    Have you tried right clicking the exe and going to properties, then finding in properties wher eit says compatibility mode, and selecting windows xp
    (that is if your using windows vista / 7)
    If windows xp compatibility mode doesnt work you could try win 98
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
    • sienoki
      sienoki
      • Jan 2012
      • 314
      #62
      Originally posted by cashkennedy
      Hehe sorry it was just a joke about mac people being idiots (wasnt aimed at you in particular as im pretty sure you have a PC)
      What file ending is the file you downloaded?
      Or does the file you downloaded from elektro tanya just have an exe that the manual is part of?
      Hey sos 4 my reply its been a very long day 4 me & now our lass is doing my head in..its a programme with a patch aswell inorder to view this manual
      So heres what ive done with this zeus setup
      Installed DWF viewer
      Installed the zeus programme then did the patch..when try to open the mainboard manual i get this error
      • selldoor
        Slow Learner
        • 7870
        #63
        Hi - i can feel the heat over here.
        If you have got the RAR file in winrar
        Double click on html folder
        It will then have Images folder and files below
        About 6 down there is one called !adj-sm.html
        Double click on it
        Is that what you need for now?
        Dont explode if its not
        • sienoki
          sienoki
          • Jan 2012
          • 314
          #64
          Double click on it
          Thx alot fella..that worked a treat..now to figure it out
          • sienoki
            sienoki
            • Jan 2012
            • 314
            #65
            So because this board came from a 37" model & its installed in a 32" the panel data needs changed,,im a little stuck here as i dont want to mess owt up..heres some info on it & would appreciate if any1 has had to change these settings before ..thx
              Do you still have the TV open?
              Look at the sticker on the back of the LCD panel. It will tell you model code and probably option numbers.
              Maybe try putting the old board back in, with the menus accessible, and copying down the panel config?
              • sienoki
                sienoki
                • Jan 2012
                • 314
                #67
                So ive put old board back in & service menu open is it only OPT4 & OPT5 being the vendor & size that need to be noted down..thx
                These are the readings
                OPT4 02D4H FEH 11111110B
                OPT5 02D5H FEH 11111110B
                Shall i just input them settings cos i carnt figure out the conversion table..thx
                These are the adjustments..sorry its a large file
                  Originally posted by Service Manual
                  Panel option data is subject to OPT4 and OPT5.
                  I would guess that only OPT4 and OPT5 would therefore matter.
                    Hmm?
                    OPT4: Encodes panel as a Samsung. (Nice! Most Toshibas have crap CMO panels.)
                    OPT5: Encodes size as 37" (doesn't seem right, however this probably doesn't matter too much as screen size is less crucial.) Backlight status is POSITIVE, status check is ENABLED, and the backlight is "forced twice" - whatever that means.
                      Do post a picture of the panel sticker on the back of the TV.
                      • sienoki
                        sienoki
                        • Jan 2012
                        • 314
                        #71
                        Hmm?
                        The 32" screen vendor is SHARP
                          Are you sure does it say that on panel?
                          • sienoki
                            sienoki
                            • Jan 2012
                            • 314
                            #73
                            Ive inputed them readings but they are not saving..not sure if theres a save button on remote after making adjustments
                              Interesting - Sharp do make nice LCD panels.
                              Maybe try MENU or OK?
                              • sienoki
                                sienoki
                                • Jan 2012
                                • 314
                                #75
                                Shouldnt any changes made in service mode be stored in EPROM?
                                Theres no factory reset in manual so im stumped
                                  Yes, probably... I'm not sure to be honest.
                                  • sienoki
                                    sienoki
                                    • Jan 2012
                                    • 314
                                    #77
                                    Nevermind it was worth a bash..i did a 100mile round trip to get this donor 37"
                                      Have you read through the service manual in detail?
                                      I don't know everything about TVs - far from it. In fact I have only repaired one Toshiba LCD and that was a dead easy fix (laying down the TV and loosening the screws.)
                                      • sienoki
                                        sienoki
                                        • Jan 2012
                                        • 314
                                        #79
                                        Ive only looked at the service settings part from how Selldoor told me..im not messing with that zeus shite as it played havock with my security..theres a service port on board but would need proper kit to mess with that & there dosnt seem to be any available firmware..
                                        Are you studying at leeds uni for a term or just a flying visit?
                                        I drive the 56 bus route outside the uni & headingly..pm me when you come i owe you a few beers for helping us out on a few sets
                                        • S2udio
                                          • Feb 2012
                                          • 16
                                          the zeus program is needed to beable to read this toshiba manual..its not the same as all others from ET..
                                          Yep spot on,
                                          For PC
                                          Install Zeus ,right click on the HTML ,file open with Internet Explorer ,
                                          Allow Active X Control ......job done,If it still don,t open IE's security level is to high... lower it !
                                          Hope the following clears a few mysteries up
                                          Got another board for my 37"........Board is marked 32,Vendor said it was from a 37...wrong.
                                          (sticker in one corner)
                                          Similar result as the pics above, except worse .....mines definately been on acid !!
                                          Wuhow trippy
                                          Using the manual config guide...bloody confusing ,and i am not new to this..
                                          And hours of trying to program my 32 board with the correct codes,
                                          In the service mode selected 37av555 (LG screen)
                                          Displays all settings correctly,save by switching off and .......
                                          Yes back to 32AV555 settings ..arrgg
                                          Then swapped the dead board 37 eprom to the working (sort off) 32 board
                                          SAME result...it loaded up the 32" settings.......????
                                          Conclusion 1
                                          the main config settings are not stored in that eprom,(ic151)
                                          It only stores user settings.
                                          Conclusion 2
                                          You cannot swap 32,37,OR 42 ,boards..they are flashed on manufacture,(that maybe stored into an onchip flash rom on the micro).
                                          Note the white sticker on the board 32 or 37
                                          Just bought a cracked screen 37 on ebay for £40..
                                          Cant be arsed to spend anymore valuable time on this one !!
                                          Most of the time things ain't what they seem to be
                                          • jord4231
                                            Toshiba 37AV500A Regza TV good power supply no sound no picture
                                            by jord4231
                                            Hi Everyone,
                                            I'm working on a Toshiba 37AV500A Regza TV.
                                            The issue:
                                            TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                                            The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                                            I checked the PSU voltages and everything looked good.
                                            No bulging caps or signs of heat.
                                            24v aud = 24.41v
                                            12v = 11.98v
                                            5v = 5.062
                                            p_o/f = Goes high...
                                            03-29-2022, 09:21 PM
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
