toshiba regza no picture
  • retiredcaps
    • Apr 2010
    • 9271
    Re: toshiba regza no picture
    Originally posted by tom66
    What do you mean by OL, what range did you have meter on?
    The Fluke 77, built before you were born, is only (by today's standard) 2.5 second display update speed and 3200 count multimeter. Modern Flukes are now 4 second display update speed and 6000 count.
    Since both readings, 3.27 and 3.28, are beyond the Fluke 77's first range (likely 3.2V) this causes it to display 0L. The Fluke 77 then moves or autoranges to the next highest range (likely 32V) and finally displays 3.27.
    Your BK 2709 is a 6600 count multimeter and would display the readings without the 0L.
    edit: Too slow typing. You already knew the answer.
    --- begin sig file ---
    --- end sig file ---
    • sienoki
      sienoki
      • Jan 2012
      • 314
      That is normal for an autoranging meter. Assuming those regulators contain "33" in their part #, they are fine.
      Are there any other regulators? Like these:
      http://www.ictradenet.com/models_pic...PAK,TO-252.jpg
      http://upload.wikimedia.org/wikipedi...4/4f/D2PAK.JPG
      http://www.national.com/images/pkg/mp04a.jpg
      http://media.digikey.com/photos/Rohm...B1132T100R.JPG
      Anything you see that looks like those could be a regulator, so note down the part # and test the pins.
      Nowt else on board looking like those if there is they will be very small..thx
      There is 1 jamicon 25v 1000uf on this board are they crap caps
        Jamicon are "okay" caps. I wouldn't trust them on the output side of an SMPS, but they are okay for general purpose use as they are probably used in this case.
        • sienoki
          sienoki
          • Jan 2012
          • 314
          I will keep looking out for a replacement board..i will probably still be looking by the time tom comes to leeds unithx anyways guys
            One potential cause of this problem is a damaged crystal oscillator - unfortunately, you would need a scope to determine this.
            • sienoki
              sienoki
              • Jan 2012
              • 314
              #26
              How many of them oscillators will be on this board?.. r they cheap & easy to replace..thx
                Usually one oscillator per processor. One for audio, one for CPU, one for video, one for DVB... Yes cheap and easy to replace if not SMD (most aren't.)
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  there is one at x1301 a metal box near the hdmi socket.
                  Question chaps In pic 4 post 13 bottom right corner there is a component FL981
                  wasted an hour this pm looking for the wiki list of component designations and when I found it FL isnt on. Any idea what it is?
                    It means filter or ferrite.
                    • S2udio
                      • Feb 2012
                      • 16
                      Hi guys my first belated post here !
                      Crt TV tech in my younger days .
                      Any thing electronic tech now !
                      I have one of these on the bench at the mo,but the 37AV555
                      Same boards etc
                      PSU board no SRV2169WW
                      Main AV board PE0630
                      Mine has a stuck in standby fault (due to the micro not sending a power TV
                      sig back to the PSU)AC det, 5V OK,Power on to PSU ok ,but the second TV on signal from the micro ...no go ?
                      With the PSU disconected it can be forced to fire up the 24v high current
                      rail ...so it appears its not the PSU,as all rails are present 5v-12v-18v-24v
                      Anyway not to hijack the thread , I have the schematics and the toshiba
                      Zeus app (to open the service manual )
                      Links
                      Service Manual (just AV board )The PSU and Inverter are 3rd party
                      http://elektrotanya.com/toshiba_32av.../download.html
                      And the zeus app for opening it,
                      http://elektrotanya.com/toshiba_zeus.../download.html
                      BTW those FL dsignations are Fusible links ,the board is covered with them
                      I would check all those for OC...Especially around the micro area.
                      Anyway ordered another AV board to continue my quest as i have spent hours with probes in hand and am convinced of a micro fault on mine,
                      We shall see,and will post back my findings.
                      Shall be watching this thread for any developments
                      Regards
                      Paul
                      Most of the time things ain't what they seem to be
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        "BTW those FL dsignations are Fusible links ,the board is covered with them"
                        That was actually what I was thinking they might be but was hoping they were
                        not. There are enough fuses: pico, glass ,ceramic, fusible resistors and the like
                        without having something else to check. I couldnt however find anywhere what the FL designation was - googled for over an hour. Do you know at what sort of
                        levels they pop.
                        Edit - Thanks for the Zeus link
                        • sienoki
                          sienoki
                          • Jan 2012
                          • 314
                          #32
                          levels they pop.
                          Thx 4 the links..cant obtain them though client not logged in error..will keep trying..i was hoping them FL,s not fusable cos there is loads..ive nowt but time to check over this board cos no replacement ready available..so im gonna check all the FL,s & maybe order another crystal..thx
                          • selldoor
                            Slow Learner
                            • 7870
                            #33
                            Do you mean cant download from ET or cant get them to run. If the former have you remembered to disable any adblockers.
                              I'm not sure they are fusible links as you would only have a few of them on the board and only near PSU inputs and things like USB... ???
                              • sienoki
                                sienoki
                                • Jan 2012
                                • 314
                                #35
                                Cant download from ET..i wait till its says get manual then it says not logged in..thx
                                • sienoki
                                  sienoki
                                  • Jan 2012
                                  • 314
                                  #36
                                  Is this the micro area & is that another crystal at the side?..them 2 small diodes are they supposed to measure the same as other diodes infinity or O.L 1 way & a reading the other way cos these 2 diodes have readings both ways..thx
                                  • sienoki
                                    sienoki
                                    • Jan 2012
                                    • 314
                                    #37
                                    sos forgot the pics
                                      Yep those are crystals, are those the only ones?
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        "them 2 small diodes are they supposed to measure the same as other diodes infinity or O.L 1 way & a reading the other way cos these 2 diodes have readings both ways..thx"
                                        Which diodes? Probably yes or at least a big difference - can you unsolder one leg
                                        Electrotanya - if you are not registered only allows two downloads (or attempted downloads per day) Im not registered and often double click and get two downloads of the same item "!!£"$%^"
                                        • sienoki
                                          sienoki
                                          • Jan 2012
                                          • 314
                                          #40
                                          yep they r the only crystals on this board X8001 is 20.000 F:86 & X1301 is 120E8C..thx
                                          • jord4231
                                            Toshiba 37AV500A Regza TV good power supply no sound no picture
                                            by jord4231
                                            Hi Everyone,
                                            I'm working on a Toshiba 37AV500A Regza TV.
                                            The issue:
                                            TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                                            The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                                            I checked the PSU voltages and everything looked good.
                                            No bulging caps or signs of heat.
                                            24v aud = 24.41v
                                            12v = 11.98v
                                            5v = 5.062
                                            p_o/f = Goes high...
                                            03-29-2022, 09:21 PM
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
