Sony KDL40S4100 question
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony KDL40S4100 question
    and for $4.99 shipping!
    • cashkennedy
      • Aug 2011
      • 668
      Your buying from ccfl warehouse too? Or did you already get it in, cause im about to order from them.
      The black plastic front bezel was also just clipped on , on my sharp, i more meant that the metal outer frame was only held on by 8 screws, and the lcd screen was attached to that metal frame, so that the inner frame / light box could easily be removed.
      Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
      • tibimakai
        • Jan 2012
        • 3680
        Yes, I have ordered from there, I'm waiting now to arrive. I can't nothing else until then. The TV takes up my whole working space.
        So it looks like they are pretty much the same construction.
        • tibimakai
          • Jan 2012
          • 3680
          I have got the tube in today (pretty fast).
          It came in a USPS triangular long box and in it it was a very thick wall PVC tube and in it the ccfl tube in a plastic tube with caps. The tube it was bubble wrapped in the PVC tube.
          I have installed it and the backlight came to life and staid that way. Yeah!!
          Now I have to put it back together and see if everything else it's OK too.
            Can we see the pictures, I never have to do lamp replace on SONY yet. By the way, this panel does not have the bad tab problem, and did the bcaklights come on for seconds and then go off due to bad lamp?
            Oh wait, is this the 4100 or the 4150?
            • cashkennedy
              • Aug 2011
              • 668
              There were 2 different models sonys he was originally cosnidering buying to fix. The kdl40s4100 is the one with bad tab bonding possibly, but the one he fixed is a different model.
              • tibimakai
                • Jan 2012
                • 3680
                Sorry about mixing in to model numbers here.
                The bulb seems a bit brighter then the rest. If it would be my TV, I would replace them all to get the maximum brightness oout of this screen.
                This way I have installed it at the top.
                The fit is very good. Maybe slightly thinner then the original. I haven't measured the new one, but the old one was 3.37mm.
                • tibimakai
                  • Jan 2012
                  • 3680
                  I have two news, one good one and one very bad one.
                  The TV works great after the tube replacement. Can't notice the brightness difference. TV has an amazing video quality.
                  Now the bad news, after popping in the black plastic frame and installing that thin metal cover I have noticed that I have cracked the screen at both lower corners. The panel itself it didn't go all the way up, I was missing like MM to pop in it's location and by tightening the cover down I have cracked it.
                  So guys pay attention when reinstalling the panel, make sure that it sits where it should sit. Do not rush it.
                  I was so excited to see if it's working that I didn't pay much attention to the panel's location.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Here are some pictures:
                    • cashkennedy
                      • Aug 2011
                      • 668
                      What a horrible turn of events. But thanks for the tip, ill be extra carefull when reinstalling mine.
                      I also learned here today that the diffuser needs to go back in the same direction as i removed it.
                        I have done that on the LCD for the monitor when I replace the lamps, but not happen to me yet on the TV, it is scarely when you try to lift up the 46 LCD panel off the frame on some of them they use the sponge with double-sided tape to hold down the LCD panel to the black plastic frame.
                        Sorry to hear about the bad news, so the panel is ruined?
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Yes unforyunatelly. Maybe I will be lucky and find another one with different issues and make one TV from two.
                          • Cheesesteak
                            Sony XBR-55A8G 4K OLED image ghosting/jumping around
                            by Cheesesteak
                            Hello All,
                            Hoping one of you wizards might be able to help me, I'm new to TV repair, I'm trying to troubleshoot a ghosting/jumping image on a 4k 55in Sony XBR-55A8G OLED TV.
                            I have tried re-seating all cables, and lightly manipulating the cables while the TV is on to see if the picture changes with pressure on any of the cables/connectors. I also replaced the TCON board and the ribbon cables connecting the TCON board to the panel, the issue has not changed with the replacements or with any cable manipulation / re-seating.
                            I saw some people had success...
                            04-18-2022, 04:35 PM
                          • Carlos#2003%
                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                            by Carlos#2003%
                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                            02-15-2024, 07:52 PM
                          • samolo75
                            Sony 49XE8096 intermittent ghosting
                            by samolo75
                            I started posting in a different thread and I was told it was not the best ans the tv model and the fault did not match. I am copping here what I wrote.
                            After starting the TV it works ok for a few seconds and then starts showing ghost image with horizontal lines intermittently (except the very top). The frequency of the ghosting is steady, like every second or so, it goes from normal to ghosting every second and back.
                            The TV is a 49XE8096. I already did quite a lot of trouble shooting. And I got the doubt if the problem is in the panel or de Tcon.
                            When disconnecting...
                            02-04-2021, 01:10 PM
                          • dkneyle
                            Sony KDL-46HX850 Can't upgrade/update firmware
                            by dkneyle
                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                            09-25-2024, 10:44 PM
                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 05:27 AM
