Philips 42PF5520D/10
  • radioredcat
    • Nov 2008
    • 8
    This plasma set is fitted with a samsung chassis and the set would go to standby occasionally it would work for days without problems.
    Taking the back off revealed 4 bulged 680uf 50v samwha caps in the power supply the other caps are capxon all rubbish casp so i intend to replace these but i am wondering if there's any other caps i should replace.
    The psu No is LJ44-00101CPS-424-PH.
    Andy
  • radioredcat
    • Nov 2008
    • 8
    Re: Philips 42PF5520D/10
    An update to this I replaced the 4 680UF 50V caps and it still kept going to standby.
    I downloaded a Philips pdf for the PSU and found there's a mod for this psu which involves the famous caps 8059/8060 3300 10V and on this PSU if you find R8094 is 910K then change it for a 1M 1%.
    After changing these components and on this PSU R8094 was a 910K it now works OK.
    Andy
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
    • double_DD
      Philips curling iron - is this a common AC cable?
      by double_DD
      Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
      As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
      Not sure if this is something Philips proprietary, or a standard, but the cable plug...
      08-18-2025, 10:04 AM
    • janos6662000
      Philips 47PFS7509/12 LCD TV problem
      by janos6662000
      Hi
      I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
      When i applied cable signal to check image, i had normal picture, but TV was restarting.
      I downloaded original firmware and applied the update, but the problem remained.
      From a colleague i received a "factory package software" which is a lot bigger.
      I made another firmware update, but still did not solve the problem.
      Somewhere on the way the error got worse, because at the moment the...
      08-12-2025, 12:54 PM
    • aidanmo
      Philips 43PUS7506/12 - Loud blown out sound
      by aidanmo
      I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
      I thought maybe the speakers got damaged, so I replaced them - no dice.
      • Using the internal speakers, it always happens.
      • Using the headphone jack, it never happens.
      • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
      02-28-2025, 03:13 PM
