Vizio SV420XVT1A LCD 2 Seconds to Black
  • Crimsonmt
    • Mar 2012
    • 64
    • United states
    Re: Vizio SV420XVT1A LCD 2 Seconds to Black
    These are the readings from J1 its a little cryptic,
    Board Definitions:
    Pins : Label
    1: PS On/Off
    2,3,4: 12v
    5,6,7,8,9: Ground
    10,11,12:5v
    13: Dim
    14:Inv On/Off
    15:VBRA
    So I took readings going into main board and they are as follows:
    Results:
    Pins : Results
    2,3,4: 11.68v
    10,11,12: 5.07v
    14:1.06v
    *when power button is pressed it spikes to 3.28
    15: 4.30v
    I will look over everything again. Following the path the best I can. I have some of the reading for U14 and U17 from last night in my notebook but as soon as the system got worse I did not post. I will post those up when I get home.
    Newbie-All Help is welcomed and I will help where I can.
    • Crimsonmt
      • Mar 2012
      • 64
      • United states
      Ok so I guess it's time to start from zero. So I want to make sure that the power board is working, how would I test that without the main board? I think that I read somewhere that if I jump pin 1 (ps on/off) with one of the 5v pins with a 3.3k resistor it should power up? Did I read that correctly or is there something else I can do?
        What do you get at pin 1 the PS_ON PIN? It should be around 2.5~5v range when you hit the power switch, it you do have the voltage, then it means the board is talking to the Power supply board.
        • Crimsonmt
          • Mar 2012
          • 64
          • United states
          It goes between .03 and .04, I seems the boards are not talking with each other anymore.
          • Crimsonmt
            • Mar 2012
            • 64
            • United states
            I have a main board coming on monday so it will be interesting to see if that gets be back to where I was in the beginning.
              Sorry for your bad luck on the board.
              • Crimsonmt
                • Mar 2012
                • 64
                • United states
                #27
                Well it was probably something I did and I chalk it up to learning so we shall see what Monday brings.
                • Crimsonmt
                  • Mar 2012
                  • 64
                  • United states
                  #28
                  So I picked up the 3.3k resistor to check the power board this weekend to make sure that the power board is up and running before I put in the new Main board on monday.
                  Quick question since this resistor will be bypassing the main board and i wont need it hooked up there are two plugs in the upper left hand corner of the board should I leave those plugged in when testing or is that something I can remove?
                    Those are the high voltage wires to the backlights assemblies, you must keep them in place or you will get real big arcing if the backlights inverter kicks on and may cause damages to the inverter circuits
                    • Crimsonmt
                      • Mar 2012
                      • 64
                      • United states
                      #30
                      I will make sure that they are plugged in when testing thanks. will update with results.
                      • Crimsonmt
                        • Mar 2012
                        • 64
                        • United states
                        #31
                        My replacement main board is out for delivery, so I will have that installed tonight and I will be picking up a 3.3 resitor to test the power board first to see when this gets me. Hopefully the replacement baord will resolve issues or atleast get me back up on the right track.
                        Will post results later
                        • Crimsonmt
                          • Mar 2012
                          • 64
                          • United states
                          #32
                          OK so i installed the new Main board and I am now back where I started. So just a refresher. Plug in vizio symbol turns amber. Press power, vizio turns white and then backlight comes on. 2 Seconds later backlight goes out. Vizio light stays white. Power button functions like normal.
                          So the question is what could be the issue? I will be retesting all voltages again to verify but if its like last time everything was good leaving the main cable to main main board. Meaning I had 5v, 12v and 24v leaving that cable. I am new at this so is there something else I should be testing?
                            So we are back to the original problem before the main board was damaged.
                            What do get at pin 14 of J1 for Inv ON/OFF? It sounds like the inverter section is bad (bad Inverter Transformers, MOSFET's for Inverter transformer driver, bad CCFL).
                            Post #21
                            "These are the readings from J1 its a little cryptic,
                            Board Definitions:
                            Pins : Label
                            1: PS On/Off
                            2,3,4: 12v
                            5,6,7,8,9: Ground
                            10,11,12:5v
                            13: Dim
                            14:Inv On/Off
                            15:VBRA
                            Results:
                            Pins : Results
                            2,3,4: 11.68v
                            10,11,12: 5.07v
                            14:1.06v
                            15: 4.30v"
                            • Crimsonmt
                              • Mar 2012
                              • 64
                              • United states
                              #34
                              Here is Pin 14 with power on.
                              Pin14:4.3v
                              Here are the new readings:
                              Power Off
                              Pin10:5.1v
                              Pin11:5.1v
                              Pin12:5.1v
                              Power On:
                              Pin1:2.4v
                              Pin2:11.6v
                              Pin3:11.6v
                              Pin4:11.6v
                              Pin10:5.1v
                              Pin11:5.1v
                              Pin12:5.1v
                              Pin13:2.8v
                              Pin14:4.3v
                              Pin 13 is the one pin that changes from once power is hit to the current on.
                              It goes from 0 to 3.3v then steadies at 2.8v
                                The Inverter ON/OFF is the one I am interested in and it is good. So now we need to dig deep to find out why the inverter section does not stay on.
                                On the two inverter transformers, please take the resistance reading on pin 3 and 4 to see if they read the same, also take the resistance reading of the 4 small blue caps close to where the lamp wires are attached to.
                                • cashkennedy
                                  • Aug 2011
                                  • 668
                                  Your original problem which is now back is most likely a problem with the inverter as budm just said.
                                  The initial way to test this is with the power disconected you want to test resistance on both of the 2 large black transformers on the top left of the power board. They should have huge pins soldering themt o the board that youll see fromt he back, and there should be at least 2 pins on 1 side, and another 2 on the other side that lead to those wires to the bulb (pink and white). You want to test resistance on both pairs of pins, for both transformers. If your unsure where to measure, then send a picture of the back side of the power supply board closeup on where the 2 black transformers are soldered.
                                  Attached is your closeup picture of the 2 transformers.
                                  Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                                  • Crimsonmt
                                    • Mar 2012
                                    • 64
                                    • United states
                                    #37
                                    Meter set at 200
                                    Top Transformer pin 1,2:0.5
                                    Top Transformer pin 3,4: 27.5
                                    Bottom Transformer pin 1,2:0.5
                                    Bottom Transformer pin 3,4: 26.8
                                    Blue Caps:
                                    TopLeft: .89 set at 20M
                                    TopRight: 27.7 set at 200
                                    BottomLeft:26.9 set at 200
                                    BottomRight:4.13 set at 20M
                                    Those reading are with power unplugged. Let me know if those meter settings are right. I bascially changed resistance until I got readings.
                                      "Blue Caps:
                                      BottomRight:4.13 set at 20M"
                                      They do not sound right.
                                      "TopLeft: .89 set at 20M
                                      BottomLeft:26.9 set at 200"
                                      Can you remove and measure them.
                                      • Crimsonmt
                                        • Mar 2012
                                        • 64
                                        • United states
                                        #39
                                        Here are the numbers off the blue caps:
                                        Top left:27j 6kv 080
                                        Top right:47j 6kv 08d
                                        Bottom left: 47j 6kv 08d
                                        Bottom right: 27j 6kv 080
                                        So that seems that I should get the same readings for TL and BR. Also should be same for TR and BL. Or maybe I am interpreting that incorrectly.
                                          When you measure these caps out off the board, make sure your fingers do not touch both probes other wise you will be reading your body resistance. These cap should read open circuits, the meter should show over range reading.
                                          They are 27pF 5% (J = 5%) 6000V, and 47pF 5% 6000V high voltage ballast caps, if you can read resistance with your meter (your meter can put out 9v maximum), just think what will happen when these caps are exposed to 2000v.
