Panasonic TX-P46G10E vertical banding
  • davidj65
    • Mar 2012
    • 5
    • netherlands
    And when i woke up switched it on, it had the stripes..
    Anyone seen this before?
    Tia
  • eTanium
    • Mar 2012
    • 65
    Re: Panasonic TX-P46G10E vertical banding
    I just read this post, while researching issues of my own, and I think it might help you:
    https://www.badcaps.net/forum/showthread.php?t=12100
    • davidj65
      • Mar 2012
      • 5
      • netherlands
      Okay that looks like my lines. So i might try to get a new board if warranty is really finished.. Reseller told me today that Panasonic might be willing to do something because its only 3 months out of warranty. Thanks for your help anyways
        Nothing to lose, try re-seating the ribbon cables from the T-CON to the panel, and from T-CON to main board also.
        • davidj65
          • Mar 2012
          • 5
          • netherlands
          Okay, but then there will certainly be no warranty.. shouldn't i wait for the panasonic guys?
            If it is still under warranty, then do not take it apart!
            • davidj65
              • Mar 2012
              • 5
              • netherlands
              well its 2 months over but that might be enough
              • Andre Gilbert
                by Andre Gilbert
                11-20-2024, 08:52 PM
              • iampivot
                Samsung 4K LCD white vertical banding in center
                by iampivot
                I'm troubleshooting a Samsung LS28D590DS 28" 4K monitor which has white vertical banding in the center of the LCD panel. The image looks like it's distorted slightly as well in the middle. Am wondering if this could be caused by the panel, t-con board or the main board?
                04-03-2022, 09:54 AM
              • mopenstein
                Looking for Vertical IC for RCA Chassis CTC159L CRT
                by mopenstein
                I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
                Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
                I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
                09-24-2023, 10:41 AM
              • Stanley1843
                Screen Display Vertical Multicolor Lines
                by Stanley1843
                Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                06-29-2024, 11:54 AM
              • kiwi2000
                2013 Panasonic 60ST60 Vertical Lines
                by kiwi2000
                My 2013 Panasonic plasma tv has a thin vertical multiple colour line. What could be the problem?
                Should I start by cleaning the flexible connectors at the bottom of the screen or there could be a problem with one of the boards? From pictures posted, need to remove brackets to get to the bottom flexible connectors.
                Changed SC board in 2018 for the 7/8 blinking red lights....
                02-18-2021, 11:47 PM
