Secondary LCD Supply Voltage
+ More Options
Posts
    Re: Secondary LCD Supply Voltage
    Is the LCD Controller just a stand alone board? And there are other main boards on this TV?
    What is the status of the TV now, it is working?
    • jkb242
      • Mar 2012
      • 175
      There are a total of 5 boards. The LCD controller board contains the microprocessor that interfaces the key inputs and communicates with the system board.
      Video is solid and look normal, there is no sound at least when the input source is connected to the HDMI input. I am going to begin troubleshooting the no audio problem tomorrow by checking other input sources to see if all audio inputs are muted or if the problem is related to the speaker relay not pulling in. I have not checked the cable or off air tuner, but have no reason to believe the set only has the audio issue at this point.
      Will post tomorrow my findings. Probably will begin a new thread entitled audio trouble.
        All this time I thought LCD controller is also part of the main logic board, now it make sense that you already replaced the main board and it still have the same symptom, sorry for not understanding all these time. Now it makes sense, great job locating the bad board. That sure a strange to have so many boards like that with a lot of cables to hook them all together.
        Does it have the audio board by itself also?
        • jkb242
          • Mar 2012
          • 175
          Re: Secondary LCD Supply Voltage-SEE New Thread--No Sound
          Budm and all,
          The initial problem has been fixed however a different problem has surfaced please see the new thread entitled Sharp LC-37D5U No Sound.
          Thanks!!
            The SAGA continues but Iam sure you will solve it eventually and that is the fun part, I will need to download the service manual for this thing. By the way, if you use the Audio Line outputs Red and White RCA jacks, do you get the sound there?
            I tell you one thing, this site is addictive!
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
              I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
              https://www.ebay.com/itm/116497313155?var=416785404161
              Here are some of the description from the eBay seller
              The main parameters:
              1. Product name: High-power non-isolated DC boost module power supply.
              2. Product model: 100A2000W.
              3. Input voltage: DC12V-60V.
              4. Input current: 100A (maximum)....
              05-18-2025, 09:45 AM
            • Jembang
              coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
              by Jembang
              good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
              11-01-2024, 09:55 AM
              LM358 LM358S-13 Datasheet
              The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
              Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
              10-07-2024, 04:12 AM
              How to modify a switching power supply that has voltage/current adjustable but powering it from a battery pack
              I have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
              I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
              what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
              I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board...
              05-11-2025, 05:22 PM
