HUMAX HDR Sat Receiver Resistor Value
  • nogger
    • Aug 2010
    • 190
    Hi all, i have a Humax HDR PVR in where the PSU has blown.
    The STR-W6252 main PWM chip has blown a leg off & a resistor that is connected to pin 3 (source & overcurrent protection pin) is o/c. I'm having trouble confirming it's value & hope someone may know on here. It seems to be a 5 band resistor but checking the banding out on several of the online calculators nothing seems to match up. Bearing in mind discolouration due to heat etc the colours are : Orange,Green,Grey (or Silver ?),Gold & then right on the end spaced further away from the others a Black band. Is it 0.35,3.5,35 or what ?
    Any help mucho appreciated.
    Graham
    Re: HUMAX HDR Sat Receiver Resistor Value
    More likely to be 0.35 Ohm since it is for the Source resistor, and per spec of the IC, it does not take much voltage drop on this resistor to trip the over current protection.
    • nogger
      • Aug 2010
      • 190
      Thanks budm, i think you are probably right. Had a look at teh burnt resistor agai today , managed to chip off a little of the enamel vovering where it had gone open & using a meter tpo measure from each end to the break (like you wold with a potentiometer) i measure approx 0.3 & 0.1 form the other end.
      Next problem where to find such a value in the UK, it's going to be a nearest value i think.
      Cheers
      Graham
        If the value is too high, then it will trip too early with lower currect than they had in mind.
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • mikey5791
          by mikey5791
          Hi to all forum members,
          12-26-2024, 04:55 AM
        • MidnightRoller
          Can a resistor lose resistance after hot air?
          by MidnightRoller
          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
          02-02-2022, 11:46 PM
        • artvandalai
          What resistor ohm will work better to repair this waterpik?
          by artvandalai
          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
          01-05-2025, 04:10 PM
        • chth96
          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
          by chth96
          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
          Since then, This AC/DC adaptor have been out of order.
          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
          And Is there any possibility that it will suddenly explode as well as to be out...
          12-03-2023, 04:40 AM
