Dell 2300MP
  • leov
    • Mar 2011
    • 45
    Dell 2300MP
    I decided to create new thread, separate from my original thread about Hitachi projector.
    This Dell 2300 MP was dropped during its cooling cycle after i finished using it. Now when I try to turn it on, the temp and lamp indicator lights stay lit while fans keep spinning.
    I was told that the lamp may be bad. I decided to take out the lamp from its housing and connect it to a different projector. When I did that, the projector turned on and the home screen appeared. For obvious reasons I did not have the cover closed so after few seconds of home screen display, the lamp and temp indicator lights come on. The projector continues to work though.
    Now going back to dell. Since the lamp is working in different projector, could there be something else that broke when the Dell hit the floor? I should also mention when I take out the lamp and try to turn on the projector (while hold down the little cover switch) I still get the same two lights as you can see on the picture.
    I posted pix of hitachi power supply unit in my other thread.
    Thanks for your help!
  • leov
    • Mar 2011
    • 45
    Re: Dell 2300MP
    any suggestions?
      Re: Dell 2300MP
      I would check for any broken solder joints or loose connectors, especially ones relating to a temperature sensor or lamp detection.
      • leov
        • Mar 2011
        • 45
        Re: Dell 2300MP
        I was trying to search the web for technical drawings/repair manual for this projector since I do not even know where the sensors are located. I was not able to find anything besides the user manual Do you know of any websites that may have something like that?
        • vestaviascott
          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
          by vestaviascott
          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
          Here's what happens:
          1) Power on
          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
          3) Blue status light flashes for appx 4 minutes...
          07-29-2020, 06:08 AM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • joesmoe91
          Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
          by joesmoe91
          My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
          02-22-2024, 07:38 PM
        • platinumsteel
          Epson VS250 Projector Lamp Not Working.
          by platinumsteel
          Hi guys gooday i have a Epson VS250 Projector that turns on and is also being recognized and detected by the computer when i plug the hdmi cable.The only issue the projector lamp is not working .Are these lamps repairable ? Or i should just forget repairing the lamp and just buy a replacement. Thanks...
          04-09-2023, 04:03 PM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
