Philips 42pf3331 and 42Pfl5603d/12
  • Tohatsu
    • Mar 2012
    • Sweden
    Okay, here are my two problems:
    The 42pf331 does after a while (sometimes 30mins, sometimes not at all) produce a high pitch noise, 18-20kHz region.
    i was told this could be the core of a drossle vibrating. My plan is to glue em all when i open it. Suggestions?
    Second issue:
    The other TV usually needs 4-6 attempts to start before the backlight lights up. The sound is OK, and after reading here, I understand that it is possible that its just the backlight not working. I have not tested this with a flashlight, as the tv is on now and will only produce the issue when it has been turned off for some time.
    I tried upgrading the firmware, as this solved a friends issues (same as mine), but it did not work.
    What info do you need from me now?
    (no need for low tech-talk, I know my way around )
    Thanx!
  • PlainBill
    • Feb 2009
    • 7034
    Re: Philips 42pf3331 and 42Pfl5603d/12
    Second issue:
    Thanx!
    Split the second TV into a second thread. It doesn't cost much, and saves a lot of confusion.
    Next a single picture of each TV. We want to see the back so we can direct you if we need additional pictures. Make the pictures as close to 2000 x 2000 pixels as possible without going over. Attach them using 'Manage Attachments' - below the test entry area.
    As for the noise in the 42pf3331, use the core from a roll of towels or a similar tube as a rudimentary telescope to isolate the source of the sound.
    I know I'm going to hate myself for this, but have you considered the problem with the 42Pfl5603d/12 might be bad caps?
    PlainBill
    • pat0te
      Tv Philips 42PFL5603D/12 random fail
      by pat0te
      Hi to all! first post here, awesome forum. Greetings from Spain. I'm a electronic technician but I forgot many things because I was working in IT all my life :-)
      I got a TV Philips 42PFL5603D/12 (chassis SQ522.2E LA) without remote control and no history to follow.
      TV has random failures. Sometimes, stucks in a rebooting loop showing white led and video and audio signals, then fixed red light (stand by?) for some seconds, then red light goes off and white light come again with video and audio showing just fine. This rebooting stages, has random working times.
      Another...
      11-19-2022, 08:09 AM
    • Cabbar
      Philips 42pfl5603d Noise
      by Cabbar
      Hi! For almost a year now, a 13 years old Philips 42pfl5603d LED TV has been making high-pitched and loud noises from the standby light's back location (right bottom) when it's turned on for the first 5-10 mins. It is only connected to a laptop via HDMI.
      During that initial time, the noise flactuates if the screen changes and lighter colors seem to increase both the pitch and the loudness. After approximately 10 mins, the sound turns into a weak buzz, and if I turn it off and back on, it's as if it has no issues.
      When the problem first began, if I turned it off and on...
      10-04-2021, 11:47 AM
    • Sharpa
      Repair attempt Philips 55OLED804/12
      by Sharpa
      I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
      The symptoms when bought: Philips logo appears then tv turns off
      Things tried so far:
      1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
      2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
      Yesterday, 08:30 AM
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
