AMC1117 Substitute Question
  • dakers1
    • May 2010
    • 5
    I have these REG1117A-ND IC 1A ADJ LW DRPOUT REG SOT223-4
    Will these work as a replacement?
    Thanks for the help
    Re: AMC1117 Substitute Question
    As long as "-4" indicates the tab, but that's rare. It has probably got one pin too many to fit.
      What are you going to use these TI regulator for as a replacement for what (what is the original part?)? Please clarify.
      Spec sheet for the REG: https://cdn.badcaps-static.com/pdfs/...054fca493e.pdf
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        I think the clue is in the heading - AMC1117 Substitute
          Ah, I missed that heading.
          • severach
            • Aug 2007
            • 1055
            To sub a 1117 you need to watch for many pitfalls:
            * Different package style
            * Different pin count
            * Different pin order
            * Adjustable or fixed, fixed come in many voltages.
            sig files are for morons
              Also the power dissipation rating, and he did not indicate if he has the fixed output type or adjustable AMC1117.
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                Yes, there will be more numbers on the AMC1117 which will indicate the voltage. I believe that some fixed ones are variable to a certain extent
                up to their max output voltage.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Not quite. You can use a fixed output type as an adjustable by adding a pair of resistors in exactly the same way they are used on the adjustable type. However, the output voltage can be varied from the rated output voltage up to as high as you want as long as you stay within power dissipation and voltage drop limits. In other words, you could use a AMC1117-3.3 to drop a 20 volt supply down to 15 volts, just don't draw too much current. (The AMC1117 is rated for a maximum power dissipation of less than 1 watt, maximum input / reference differential of 13 volts. In the scenario I described the maximum current would be 200 mA.)
                  PlainBill
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • the_rem
                    Unknown transformer : how to find a good replacement part ?
                    by the_rem
                    Hello guys,
                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                    04-23-2025, 01:48 AM
                  • ezenia
                    PS4 controller left stick potentiometer replacement issue
                    by ezenia
                    Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                    So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                    I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                    09-30-2023, 02:19 PM
                  • boosti45
                    Macbook pro logic board replacement parts quesion
                    by boosti45
                    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                    08-21-2024, 05:23 AM
                  • r2digital
                    klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                    by r2digital
                    I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                    04-18-2024, 03:50 PM
