Re: Samsung LE37A556P1F Flashing red light
Ok
CH? 17-33 0818BG
CH? 17-18 0814BG
ch? 1117 0819BG x 2
17-25 0807AG
KIA 78D015F
Those are the ones I can see on the main board.
They will not be all the same, there should be some kind of marking on those regulators, we need the numbers so we can look up the spec for them.Leave a comment:
Well, that main board is not working as far as the BL ON signal, second thing will be that you can now turn on the backlights for the light source, then you should see the pictures on the screen, if not, then you have more problems on the main board beside no BL ON signals. Power supply section on the main board will have to be checked next since it has a bunch of voltage regulators on the main board.
I can see about 5 voltage regulators on this board. Do you want the readings from all of these along with their model numbers or should they all be the same?Leave a comment:
Well, that main board is not working as far as the BL ON signal, second thing will be that you can now turn on the backlights for the light source, then you should see the pictures on the screen, if not, then you have more problems on the main board beside no BL ON signals. Power supply section on the main board will have to be checked next since it has a bunch of voltage regulators on the main board.Leave a comment:
There is a pic of my meter at the beginning of this post I am guessing that the dial need to be at point to the very bottom with the probes in the same place as if i were measuring diodes?Leave a comment:
At this point, we want to verify that the transistor is being told to turn on, it should goes off when the TV is turn on, so it sounds like you have main board problem.Leave a comment:
The inverter may have Pulled up resistor on it already.Leave a comment:
What you can do is to set your meter to DC AMP mode (you know how to do that right) and just connect the probes of the meter to the E and B, that should do it also.Leave a comment:
Also when Connector 2 is not connected to the mainboard the backlight comes on really bright so how can it do that with no BL_ON signal connected?Leave a comment:
I haven't got any loose resistors here that the moment to try it out I will have to pick some up tomorrow.
Is there anything else I should pick up while i'm at it?Leave a comment:
Try shorting out that Base and the Emitter with the 100 Ohms and see if the BL is ON.Leave a comment:
By the way, since a lot of TV use Common Emitter circuit to drive the BL_ON or PS_ON signal, if you use the 3.3k Ohm resistor connect to 5vdc and PS_ON or BL_ON, you will not be to bring that signal up if the transistor is already on, the transistor will load down the 3.3k resistor, that is why you need to disconnect the cable attached to the main board to manually turn on the P.S, or the Inverter board.Leave a comment:
I connected Connector 2 and 3 then used the multimeter to check continuity between the collector of Q6101 and the BL pin of connector 1 and as you say they do link through.Leave a comment:
That mean that transistor is being told to turn on by the processor, that is the why the Collect voltage is low and that is why you are getting 0.1v at the BL_LINE.
You can turn that transistor off by connecting a 100 Ohms between the "E" and "B' pins of the transistor, then you should see BL goes high toward 5VDC, if it does not go up, then it may have "E" to "C' shorted out. You can try Ohming out "E" and "C" first if you want.Leave a comment:
Connector 1 is giving off 12v but I cant check all of the pins on Connector 3. I know that its definitely giving the board power as the optical output lights up and there is power across off of the voltage regulators.Leave a comment:
1, This end of the resistor connects to the collector of Q6101 - YES
2, BL_ON Signal OUT? - Checked again and it definitely that pin the one next to it is ADIM which connects to the second resistor from the left of the next group of 4 resistors.
3, Measure B and E - Using the negative probe on E and the positive on B this gives me 0.7V does this mean its connected to ground?Leave a comment:
You are correct, you should get the sound if you do have the 12vdc power supply section working as you have indicated.Leave a comment:
OK, please see the attached PDF and verify if that BL_ON is really the BL_ON PIN, also verify the "E" and "B' voltage reading of that transistor. I think the transistor is on right now, it is a Common Emitter connection setup for this transistor.Attached FilesLeave a comment:
Hi the original board that came with this TV is still in place.
I ordered the second board as sold as seen for £6 knowing that it might not be the right one but I thought it was worth a look. It something I can possibly use for parts or testing my soldering skills / or lack of.
I know his posts are confusing. He made a mistake making his first one.
So that resistor seems to be dropping 5v over it?
Should I not be getting sound regardless of this pin not getting its 5v?Leave a comment:
by learnmoreHello Community!
CASE DETAILS
Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
Tried inserting firmware on USB and left it in for a few hours, but no change
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by Phil289Hi
I aquired a Samsung UE46EH5000 from a lady that said it was turning on and off so she just purchased a new one.
On plugging into the mains and turning on i get a solid red light.
On using the on/off button or remote i just get a flashing red light in a pattern of flash/flash gap flash/flash gap flash/flash etc.
Opened it up and disconnected the main board from the power board by removing the connecting ribbon cable with the hope of getting either a 'no backlight' or a 'working backlight' but got neither,i just got a blinking backlight that turned on and off randomly... -
by esqmoooHello everyone.
This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
I tried long pressing on the power button, after several seconds it would go off then when the button is released... -
by JackchingI know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
- Loading...
