I've got my 40" lcd!!!! (1080p!!)
  • py3m4n
    • Jul 2011
    • 99
    • Scotland
    Re: I've got my 40" lcd!!!! (1080p!!)
    Sounds to me like you have got your new toy up and running and you are being picky, hahahahaha.
    Sounds like a backlight uniformity issue, something that just exists with LCD technology, part of the reason manufacturers moved on to LED technology, that, and they want you to buy the next big thing! If your being picky you can almost always find this on a dark screen on LCD's (any I have put under scrutiny anyway, in particular I have found it more prominent in Samsung LCD's)
    Stop looking for issues, be proud and enjoy 2001! hahahahaha!!
      To fix the light area, loosen the case screws. (Just a little bit... still plenty to hold the TV together, but not maximum torque.)
      Seriously, it fixed it on a Toshiba LCD I have. Dark patch in the centre of the screen caused by screws that were too tight, applying too much pressure to the LCD panel.
      The technical term for it is mura, and it is caused by unevenness of the liquid crystal in the LCD panel. Whilst it is a permanent defect, it is made much worse by the case design.
      I bet you've got a Chi-Mei LCD panel, those are rubbish and very prone to mura.
      • Paul678
        • Nov 2011
        • 402
        I loosened the case screw in that corner, but
        didn't really do anything. But it DOES look like
        some sort of pressure is being applied to that
        corner. You know how you can make an LCD
        panel brighter by pushing your finger on it? Looks
        like the front plastic bezel may be putting some
        pressure on this corner.
        You can only barely see it when the screen is pitch
        black, and that's only if you are looking for it.
        Most of the time you cannot see it.
        Py3, you are correct! I'm being WAY too picky!
        The picture is beautiful! This website is the
        coolest! Thanks for all the input!
        • py3m4n
          • Jul 2011
          • 99
          • Scotland
          What's your backlight settings at? have you tried just turning it down a bit to see if it makes a difference?
          Your right about this site. After what Tom has just said about mura I am reckoning that's whats up with a friends T.V and it's not a backilght uniformity issue like I had presumed. It is more likely thermal stress over the years on the LCD panel itself (his telly is around 5/6 years old and well used).
            *All* of the screws, not just the one on that corner. The problem on the Toshiba was on the centre, but more on one side. Would recommend doing them all, that fixed it.
              I think backlight uniformity is considered the same as mura, but caused by the filter layers in the backlight system distorting. It is definitely accelerated by thermal stress, like normal LCD mura. It may be repairable, but the filter layers are probably next to impossible to buy in low quantities. I tore apart a Philips LCD TV with a broken screen. There were about 6 diffusers(!) and a prism film. A prism film is a really cool piece of material. If you shine a light through it, it makes it appear brighter. How does it do it? It makes the light more perpendicular, i.e. directional, going one way not various different ways. Easily brightens the screen by 15-20%... now that's simple and clever design.
              • py3m4n
                • Jul 2011
                • 99
                • Scotland
                #27
                @Tom
                If your interested, done one a bit of research on the differences between the picture on Xbox 360 when comparing component and HDMI. Looks like it might be down to the way that the Xbox's circuitry processes the analogue to digital conversions (i think that's right,lol) which is not very well by the sounds of it. I think further reading is required for me to fully grasp it...
                • Paul678
                  • Nov 2011
                  • 402
                  #28
                  Ok, a bit more nit-picking: The big "Journey" letters
                  from the Journey DVD menu, along with the box surrounding
                  the over-the-air TV channel display, appeared to be very
                  faintly burned into the screen image during the first 15 minutes
                  or so. The very faint burn-in was not noticeable when the background
                  was either very dark or very bright.
                  They appear to be gone now, but is this normal
                  to see on LCD while the tv is warming up?
                    That is typical for most LCDs. They exhibit temporary image retention. Mine does it if you have an image on it for more than about 20-30 seconds.
                    • Paul678
                      • Nov 2011
                      • 402
                      #30
                      Ok, good to know. It's very hard to notice
                      at first, and you really have to look for it, and even
                      then, it disappears completely most of the time,
                      depending on what the displayed picture is.
                      OVERALL IT'S FANTASTIC! I love the picture! It's obviously a lot
                      nicer than my 2004 Insignia NS-32LCD, which I'm now
                      trying to sell. This Proscan is a 2009 model, so it shows you
                      how far they progressed in 5 years, particularly with respect
                      to the wider viewing angle (blacks on the Insignia get pretty
                      grey if you aren't facing straight into the screen).
                      Ok, I'm ready for another one! haha!
                      Thanks for all the feedback, guys.....
                      • py3m4n
                        • Jul 2011
                        • 99
                        • Scotland
                        #31
                        Ok, I'm ready for another one! haha.
                        He has been bit!
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          If you REALLY want to get a "wow" effect, download Big Buck Bunny in 1920x1080, connect your computer up to the TV (via VGA or whatever) and watch it
                          I know that feeling.. We had a 9 or 10 years old 70cm (28") 4:3 CRT TV (Vestel turk crap chassis.. i think 11AK33) up till about 3 months ago, when the main filter cap (400V 150uF G-Luxon from 2000) randomly decided to go pop violently (whole can was egg-shaped), and somehow killed half the SMPS in the process.
                          Put a little (i think 20") CRT TV up temporarily.. anything but ideal for a big living room lol.
                          Fast forward a bit, and now we're watching TV on a 40" 1080p Samsung LE40A536 that I managed to fix after LOTS of frustration (ended up being a bad mainboard).
                          There just isn't any comparison. SD TV looks like shit (blurry pixelated mess cause it gets upscaled), but feed it 720p or 1080p material and it looks awesome
                          edit: yes... it was LOUD
                          http://bambooz.pytalhost.net/badcaps/vestel-11ak33.jpg
                            Hah. That looks bad. Interestingly the service manual says 330u 400V is to be used. I'm guessing they made the cap smaller till it stopped working (at least for a couple of minutes), classic Vestel design procedure it seems!
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              Well.. it worked for 10 years. And we got it used, so idk how old it actually is.
                              It's rebranded as a Universum FT 81026 (1, 2)
                              The chassis is an 11AK33-1 actually. No idea if that makes any difference.
                              In the whole time since we got it, it only had 2 repairs done to it.
                              One was failed solder joints in the HV area under the chassis (image became blurry every now and then). Fixed with LOTS if leaded solder (resoldered just about every joint that looked even slightly abnormal)
                              The other one was a randomly shorted bridge rectifier, which ironically blew the little fuse in the power strip it was plugged into, but not the one in the TV itself
                              Otherwise nothing done to it. Ever. Quite suprising for a POS Vestel.
                              I was hoping to fix it up again after the LCD TV turned out to be a nightmare.. replaced a bunch of components in the SMPS area and a bunch of caps all over the place (it had developed an issue with random characters in the teletext being either wrong or just blank.. with sometimes quite hilarious results).. But I never ended up testing it after that and kinda forgot which connector goes where by now (it's been sitting for 3 or so months now).
                              I'm quite undecided wether I should dump it or try to get it working to have my own TV. I actually don't have one since '04.. was fed up with the 24/7 BS.. Nowadays it might come in handy for my various analog video stuff I'm trying to transfer to digital formats and also some retro-consoles, which don't really work too well with LCDs (input lag, format/aspect problems)
                              [/StoryNoOneCaresAbout]
                              • AstutePauciloquent
                                Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                by AstutePauciloquent
                                Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                11-23-2023, 11:02 PM
                              • CoinCoin88
                                Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                by CoinCoin88
                                I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                09-15-2025, 03:36 AM
                              • howardc64
                                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                by howardc64
                                Failure Symptom
                                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                Where is the short?
                                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                05-27-2025, 02:56 PM
                              • JayPoorJay
                                Converting +/- 5v to a Usable Hz Signal
                                by JayPoorJay
                                Good morning.
                                I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                                This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                                The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                                08-07-2022, 08:35 AM
                              • Scruit
                                What is a normal composite signal range for a C64?
                                by Scruit
                                Hello all,
                                Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
                                More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
                                https://imgur.com/gallery/PpqcqPY
                                My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
                                More detail:
                                Symptoms are that that I get...
                                04-28-2022, 05:33 AM
