Lg 23lx1rv
  • PlainBill
    • Feb 2009
    • 7034
    Lg 23lx1rv
    This was a freebie from a member here, Thanks David!!!
    My first reaction was indifference. It had a very unusual display problem (see attachments (I zipped the video)) which I tentatively felt was either tcon or panel, and the built in DVD player did not seem to be working, so I set it aside. When I checked the price of a tcon I discovered it would cost less than $20, so there was a potential profit to be made.
    Before ordering a tcon, I examined the display again and realized it looked like it was missing sync signals. That would be the main board, and unreasonably expensive for a 23" TV. Then looking at the service manual I realized the DVI input went directly to the gm5221 chip. Hooking it up to a computer showed the same problem!!!
    That reduced the possibilities - A bad gm5221 or a bad regulator. Power for the gm5221 comes from a pair of dedicated regulators 3.3 and 1.8 volts. The 3.3 read 3.31 volts, but the 1.8 read 1.76, slightly low. At this point I pulled out the scope and looked at the power supply lines. The 3.3 volt line was clean, but the 1.8 volt line had over 1V p-p of noise riding on it. The output of the 1.8 volt regulator was filtered by a pair of 47uF, 16V caps, so as a final step I tried hooking a 100uF, 25V cap in parallel with them. When I powered up the set I was happy to see a clean 1.8V rail, and a stable 'No Signal display on the screen. I pulled the original SMT caps and replaced them with a pair of 47uF low ESR caps and the TV is working perfectly.
    The DVD problem turned out to be a combination of problems - the DVD player is disabled if it is not the selected input - and the DVD I was using for testing (E.T. - The Extraterrestial) was rejected by the player, while it found 'Knowing' perfectly acceptable.
    PlainBill
    Re: Lg 23lx1rv
    Very strange. So the 47u/16V general purpose capacitors were failed? I would not have expected that...
    • PlainBill
      • Feb 2009
      • 7034
      Re: Lg 23lx1rv
      I believe so. There was evidence to indicate something had vented in the area. The ESR tests indicated they were marginal (I don't have a capacitance meter that goes that high). I can't think of a failure mode for the regulator (a LD1086DT18) that would result in oscillations that could be eliminated that easily. The amplitude of the noise was about 1volt, if it was due to a failure of the regulator I would have expected it to be reduced by a low ESR cap, but not eliminated. A further indication - with the cap in place the voltage rose to 1.807 volts
      PlainBill
        Re: Lg 23lx1rv
        PlainBill
        I'm guessing that the voltage regulator was some kind of LDO. Most LDOs have a limited range of stability - they like an ESR between 0.2 and 4 ohms, for example. It's possible the cap's ESR exceeded this, causing the instability. Or, if there were other caps in parallel with the general purpose ones (for example for decoupling), it could reduce the apparent ESR, also causing instability.
        Do you remember what frequency the ripple was at? Several kHz?
        • PlainBill
          • Feb 2009
          • 7034
          Re: Lg 23lx1rv
          The regulator is an LDO (1086 family) device. The noise wasn't ripple, it appeared to be a fairly broad spectrum.
          PlainBill
          • Paul678
            • Nov 2011
            • 402
            Re: Lg 23lx1rv
            PlainBill
            Bill, when you say, "I realized it looked like it was missing sync signals",
            can you describe in more detail what you were seeing?
            I imagine it's something like the picture rolling vertically, like when
            you didn't have the vertical control adjusted properly in an older
            CRT tv.
            • PlainBill
              • Feb 2009
              • 7034
              Re: Lg 23lx1rv
              CRT tv.
              More or less. The picture would look like it was rolling vertically like we loved to see back in the days of vacuum tube TVs, but it also seemed to drift side to side at times.
              PlainBill
              • spinger
                • Nov 2012
                • Colombia
                Re: Lg 23lx1rv
                Hello PlainBill.
                I just wanted to thank you because you helped me solve a problem I had with this TV.
                Thank you very much
                • skullking123
                  • Aug 2011
                  • 5
                  Re: Lg 23lx1rv
                  Hi guys I'm trying to find the capacitors that I need to change for this fix. I found the gm5521 chip but not sure which caps are the ones needing to be changed. A bit of a newbie so any help would be much appreciated.
                  Here's pic of the board:
                  • selldoor
                    Slow Learner
                    • 7870
                    Re: Lg 23lx1rv
                    There are only 10 ordinary caps on the board. Plainbill seems to have changed the 47uf16v caps. You can either try just those or replace them all- have you checked the voltage regulators as he did? You dont say what is wrong with the set.
                    You should be able to get the caps at digikey - you dont say where you live - please update your profile with at least country and mains voltage. I would use panasonic Fm or Fr series if you can get them in the sizes you need - you also need to be sure you get the same (or smaller physical size so that they will fit the space.
                    • skullking123
                      • Aug 2011
                      • 5
                      Re: Lg 23lx1rv
                      Oh sorry, the issue looks to be the exact as what Plainbill was experiencing. I meant to ask where to find the power regulators so I could test them and in turn find the correct capacitors to replace.
                      I have used digikey before but I would like to test the regulators before buying the caps.
                      Here's a pic of the power board in case it is needed:
                      • selldoor
                        Slow Learner
                        • 7870
                        Re: Lg 23lx1rv
                        You need to read this
                        https://www.badcaps.net/forum/showthread.php?p=261329
                        I cannot identify all the regulators some look like regulators but you can only be sure by getting the part numbers and checking the datasheets.
                        As a start on the left in your pic just by the connector with alternate blue gray wires there is one LMS1587 3.3.
                        The power supply needs a good dusting with a soft brush
                        Please update your profile
                        • skullking123
                          • Aug 2011
                          • 5
                          Re: Lg 23lx1rv
                          Thank you selldoor for that great tutorial. Had some time to check the regulators and their values were very similar to PlainBill's. The 3.3V regular was reading a 3.29V but the 1.8V regulator was reading 1.745V a tad bit less than what PlainBill was getting.
                          If I'm not mistaken I believe the 47uF 16V caps that PlainBill replaced include the cap under the bottom left corner of the gm5221 chip and the cap on to the bottom-left of that one. Looks like there are 2 traces coming out of the 1.8V regulator to those two caps.
                          Please let me know if you see it differently and also would appreciate some help finding the correct replacement caps.
                          • selldoor
                            Slow Learner
                            • 7870
                            Re: Lg 23lx1rv
                            Cant tell could be either two of the four - I might be inclined to change all four and if it was a bad batch perhaps all the 16v47uf ones as postage may be your biggest outlay.
                            I think he didnt replace with SMT he used radial low esr ones.
                            • skullking123
                              • Aug 2011
                              • 5
                              Re: Lg 23lx1rv
                              Went ahead and ordered the four since price isn't really an issue. Now just have to wait for them to arrive.
                              Thanks again for the help.
                              • skullking123
                                • Aug 2011
                                • 5
                                Re: Lg 23lx1rv
                                Thought I would update. Caps arrived in mail today and I went ahead a replaced the two that I suspected were the cause. Turned it on and voila it's fixed.
                                Thanks again selldoor for the help and PlainBill for finding the fix.
                                • slothen92
                                  Volvo HU850 Radio/CD-player repair, LDO-voltage regulator IC
                                  by slothen92
                                  Hello
                                  Im trying to repair the Volvo HU850 radio/CD-player from a Volvo V70.
                                  I have ordered replacements for the four transistors (SD1760), but Im not sure about a replacement for the low dropout voltage regulator IC (marked by the red circle in the attached picture).
                                  On the body of the IC it says: “LF33AH GK133544”.
                                  Does anyone know where to find this part or a replacement for it?
                                  Cheers
                                  04-09-2025, 08:30 AM
                                  MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
                                  This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                  09-06-2024, 05:30 PM
                                • GraphicMan
                                  rio volt portable mp3 cd player.What type of caps are these?
                                  by GraphicMan
                                  Hello
                                  this is a rio volt portable mp3 cd player main board
                                  accidentally its 120ac power adapter was used with 220ac
                                  the unit worked for few seconds and then off and never worked again
                                  it normally takes 3volts batts or 4.5dc from the adapter socket
                                  in the picture I believe this is the main power IC (4 channels)
                                  it is the only area in the board that barely gets warm after few minutes
                                  drawing 0.4 watts in total continuously
                                  i did checked all the caps on the board including these caps around the IC
                                  nothing is shorted...
                                  09-11-2022, 07:52 PM
                                • disorder
                                  HP 2311 display, 3.3v regulator fried, need help to replace
                                  by disorder
                                  hello,
                                  i have a hp display 2311 to repair, totaly dead
                                  on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                                  i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                                  thank you
                                  Yesterday, 04:34 AM
                                • kokopelli75
                                  Victrola multi-player - No audio
                                  by kokopelli75
                                  Hello!
                                  My mother has a Victrola Navigator player that stopped functioning after a storm. I checked out what I could - all player functions appear to work, but there is no audio output in either the speakers or the headphone jack. I suspect (with my limited knowledge) that the amplifier part of the device is toast. Photo of the suspected board is attached. There's separate boards for front display, record player, etc. This board has a section for power regulation and a section for amp. There's a UTC7266 7+7W dual bridge amplifier IC and a CSC2314F sound processor IC on the board. Visually,...
                                  01-11-2025, 03:51 PM
